Data Protection
Primary Snapshot Retention when using External_Snapshots
mmodi
I was proposing the use of Snap Creator to centrally trigger SnapDrive backups on all hosts and was hoping to get some help with managing retention on primary -
  • When using External Snapshots it seems like Snap Creator does not manage retention (neither primary nor secondary)
  • Protection Manager on the other hand understands the backup version on primary but only manages retention on Secondary i.e. Backup node.
  • If neither SCF nor OCUM is managing primary retention, am I looking at a custom script for SnapDrive based retention?
    • Obviously, the use case is typically managed by a SnapManager but in this case we are leveraging SnapDrive directly.
1 ACCEPTED SOLUTION
mmodi
Thanks John Spinks
  • I have taken your advice using Snapshot create command (without External_snap) and Snap Creator is now handling the primary retention policy. Also, realized that I don’t require using external snapshot in this case as SnapDrive created snapshot integrates with Protection Manager dataset using SCF anyway.
########## Checking Protection Manager dataset mm-dfm ##########
[2014-04-01 12:47:26,916] DEBUG: <dataset-modify>
<edit-lock-id>1392800517</edit-lock-id>
<dataset-name>mm-dfm</dataset-name>
<is-application-data>true</is-application-data>
<application-info>
<is-application-managing-primary-backup-retention>true</is-application-managing-primary-backup-retention>
</application-info>
</dataset-modify>
########## Running Snapshot copy Delete on Primary ##########
[2014-04-01 12:50:40,465] INFO: STORAGE-02013: Removing Snapshot copy [backup-daily_20140401120349] on volume [testvol]
[2014-04-01 12:50:40,465] DEBUG: <snapshot-delete>
<snapshot>backup-daily_20140401120349</snapshot>
<volume>testvol</volume>
</snapshot-delete>
[2014-04-01 12:50:40,465] INFO: STORAGE-02014: Removing Snapshot copy [backup-daily_20140401120349] on volume [testvol] finished successfully.
[2014-04-01 12:50:40,470] INFO: Application not defined. Skipping cleanup task
1 REPLY 1
mmodi
Thanks John Spinks
<application-info>
</application-info>
</dataset-modify>
</snapshot-delete>
