Data Backup and Recovery
Problems with SC 3.4 & PM integration
thorsten_pfeifer
Hi all
I get this error
Remote host closed connection during handshake
when I enter the credentials for the PM/OM integration using the SC configuration wizard.
Question: should this be a local user from the SC Server or can domain user be used as well? If yes which rights do the need on the SC Server (local Administrators group for example)?
Can anybody help me out with this issue?
Thanks a lot
Best regards
Thorsten
2 REPLIES 2
ktenzer
This works fine
OM_HOST=scdfm.muccbc.hq.netapp.com
OM_USER=MUCCBC\ktenzer
OM_PWD=53616c7465645f5f0e89baf7bf2b8ccefaf70903a0a9722ef85317cf022f0f64
OM_PORT=8088
OM_EVENT_GENERATE=Y
Make sure OM_PORT is correct. If TRANSPORT=HTTP OM_PORT=8088 if TRANSPORT=HTTPS OM_PORT=8488
Regards,
Keith
pascalc
Keith,
I suggest you add this example in the admin guide...
