Data Protection
SME Issue
sysadmin_hmgcc
Hello
I'm having a small issue with Snap Manager for Exchange.
Setup.
J:\Data - This is the LUN where the DB's live.
J:\Logs - This is the LUN where the Logs and SI live.
As you can see I have two LUN's and exchange has been living happily on them for several weeks. I then wanted to setup DMF integration so ran the sdcli dfm_config command on the box. Now when i try to re-run the configuration wizard for DFM integration I get this message:
"The minimum number of Data OnTap LUNs to run SnapManager is Two. Please create more LUNs using SnapDrive then re-run configuration wizard."
The annoying this is I can still run through the whole of the configuration wizard but it just cant detect the Protection Policies from DMF.
I have tried disconnecting both LUNs and re attaching, restarting SME and SD services, and rebooting the box.
Can anyone help me with what to try next?
Thanks
Nick
1 ACCEPTED SOLUTION
sysadmin_hmgcc
SME upgrade from 5.0 to 6.0 Fixed this issue.
1 REPLY 1
sysadmin_hmgcc
