Data Protection
SME and RDM's Virtual Compatibility Mode (VMware)
EwyWins
Right to the point. We have MS Exchange virtualized (vmware) and are using RDM on physical compatibility mode for the DB luns. The Exchange DB luns are presented via FC HBA. We rely on SME 7.2 for Exchange backups. I would like to change the RDM Compatibility mode  from physical to virtual so that I have more flexibility later during a storage migration to a new HCI cluster.  Will this affect SME backups. Is there anything else i need to consider for this change besides SME. I have read the SME 7.2.1 Install and Setup guide but could not find anything there.
Thanks in advance.
2 REPLIES 2
RajeshPanda
@EwyWins Let me know if you are still looking for the solution, i will help you find an expert who can answer to your query.
NTAp-AVS
SME is dependent on Snapdrive . Snapdrive has limitation that it only supports Physical Compatibility Mode.
So please do not modify the RDM-Compatibility Mode
