Data Backup and Recovery
Hi,everyone,
I have error in mount a error in oracle using ASM, how can i solve this problem?
--[ INFO] SMO-13046: Operation GUID ff8080812890c089012890c08dd20001 starting on Profile PROFILEASM
--[ INFO] SD-00028: Beginning to connect device(s) [/dev/sdg] from snapshot smo_profileasm_orcl_f_h_1_ff808081288f6c5801288f6c5dc20001_0.
--[ INFO] SD-00029: Finished connecting device(s) [/dev/sdg] from snapshot smo_profileasm_orcl_f_h_1_ff808081288f6c5801288f6c5dc20001_0.
--[ INFO] PLAT-00010: Creating mapping from disk "/dev/sdb1" to raw device "/dev/raw/raw10".
--[ INFO] ASM-00500: Changing ASM Disk Group name in header of disk /dev/raw/raw10 from DG1 to DG1_20100513162059538_1.
--[ INFO] ASM-00000: Mounting ASM Disk Group DG1_20100513162059538_1 on host dell67.
--[ERROR] FLOW-11019: Failure in ExecuteConnectionSteps: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100513162059538_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
ORA-15024: discovered duplicately numbered ASM disk 0
--[ERROR] FLOW-11010: Operation transitioning to abort due to prior failure.
--[ INFO] SD-00019: Discovering storage resources for all system devices.
--[ INFO] SD-00020: Finished storage discovery for all system devices.
--[ INFO] SD-00034: Beginning to disconnect device(s) [/dev/sdb].
--[ INFO] SD-00035: Finished disconnecting device(s) [/dev/sdb].
--[ WARN] FLOW-11011: Operation aborted
--[ERROR] FLOW-11008: Operation failed: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100513162059538_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ERROR] SMO-13032: Cannot perform operation: Backup Mount. Root cause: SMO-11007: Error cloning from snapshot: FLOW-11019: Failure in ExecuteConnectionSteps: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100513162059538_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ INFO] SMO-13039: Successfully aborted operation: Backup Mount
--[ERROR] SMO-13048: Backup Mount Operation Status: FAILED
--[ INFO] SMO-13049: Elapsed Time: 0:00:33.300
Solved! See The Solution
Hi my friend
This is neto from Brazil
How are you?
Let me check the diagnostic file. Using SMO 3.0.2 and later ASMLib is not more a requirement.
I will double check the file and I back to you.
All the best
neto
Hi All
How are you?
IMHO the issue is:
Based on it, you have mounted sdb1 to raw10 and worked.
Seems to me that ASM instance doesn't have configure the ASM disktring and ASM is trying to discover all disks and ASM could be discovering two disks with same id (sdb1 and raw10).
You could try to use the following on ASM configuration: (ASM disk string)
Add:
/dev/raw/, /opt/NetApp/mount/
Please let me know the results
All the best
neto
Thanks neto
Before test smo mount for ASM,I have set ASM configure asm_diskstring='/dev/raw/raw*'
ALTER SYSTEM SET asm_diskstring='/dev/raw/raw*' SCOPE=BOTH
so ASM should not discovery other path, such as /dev/sdb1
How smo change the header name disk /dev/raw/raw10 from DG1 to DG1_20100513162059538_1
Hi my friend
How are you?
Worked?
All the best
neto
my os is rhel5.4,and smo's version is 3.0.0 for linux
Automatic Storage Management support library (ASMLib) must be used when using ASM with iSCSI or FCP on Linux.?
And that version of SMO is not supported with RHEL 5U4. You need to be
on either 3.0.2 or, preferred, 3.0.3 and be using SDU 4.1.1.
-Mark
Sorry,my smo's version is 3.0.3, not 3.0.0
Does smo for linus only support asmlib, not support raw device?
But what I suggested worked or not? I didn't understand
Hi, neto
I set asm_diskstring to /dev/raw/, /opt/NetApp/mount/ ,but smo mount report the sam error.
Could you please do me a favor
export ORACLE_SID=+ASM
sqlplus / as sysdba
show parameter asm
The asm configure paremater,asm_diskstring has been set to /dev/raw/raw*
SQL> show parameters asm
asm_diskgroups string DG1
asm_diskstring string /dev/raw/raw*
asm_power_limit integer 1
Could you please copy here the exactly error?
New error information for smo mount:
asm_diskstring has changed to /dev/raw/raw*
--[ INFO] SMO-13046: Operation GUID ff808081289458650128945869dd0001 starting on Profile PROFILEASM
--[ INFO] SD-00028: Beginning to connect device(s) [/dev/sdg] from snapshot smo_profileasm_orcl_f_h_1_ff808081288f688501288f688a0a0001_0.
--[ INFO] SD-00029: Finished connecting device(s) [/dev/sdg] from snapshot smo_profileasm_orcl_f_h_1_ff808081288f688501288f688a0a0001_0.
--[ INFO] PLAT-00010: Creating mapping from disk "/dev/sdd1" to raw device "/dev/raw/raw11".
--[ INFO] ASM-00500: Changing ASM Disk Group name in header of disk /dev/raw/raw11 from DG1 to DG1_20100514090543623_1.
--[ INFO] ASM-00000: Mounting ASM Disk Group DG1_20100514090543623_1 on host dell67.
--[ERROR] FLOW-11019: Failure in ExecuteConnectionSteps: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100514090543623_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ INFO] SD-00034: Beginning to disconnect device(s) [/dev/sdd].
--[ INFO] SD-00035: Finished disconnecting device(s) [/dev/sdd].
--[ERROR] FLOW-11008: Operation failed: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100514090543623_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ERROR] SMO-13032: Cannot perform operation: Backup Mount. Root cause: SMO-11007: Error cloning from snapshot: FLOW-11019: Failure in ExecuteConnectionSteps: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100514090543623_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ INFO] SMO-13049: Elapsed Time: 0:00:23.617
Could you please collect
Connect to ASM instance
select name, state from v$asm_diskgroup;
select name, path from v$asm_disk;
SQL> select name, state from v$asm_diskgroup;
DG1
MOUNTED
SQL> SQL> select name, path from v$asm_disk;
/dev/raw/raw8
/dev/raw/raw7
/dev/raw/raw6
/dev/raw/raw3
/dev/raw/raw4
/dev/raw/raw2
/dev/raw/raw10
DG1_0000
/dev/raw/raw1
8 rows selected.
Please do me a favor
Disconnect /dev/raw/raw10
Run the same commands again
Make sure that raw10 is disconnected
raw -qa
Check also if the clone has been disconnected.
Try again, because seems to me that the rename worked (see DG1_0000)
Please run again and collect the SMO diagnostics
[root@dell67 log]# sanlun lun show
controller: lun-pathname device filename adapter protocol lun size lun state
fas3050-31: /vol/vol4/lun2_20100513162059502_1 /dev/sdb host20 iSCSI 3g (3221225472) GOOD
fas3050-31: /vol/vol2/lun3 /dev/sdc host20 iSCSI 50g (53687091200) GOOD
fas3050-31: /vol/vol4/lun2 /dev/sdg host20 iSCSI 3g (3221225472) GOOD
fas3050-31: /vol/vol2/lun6 /dev/sde host20 iSCSI 2g (2147483648) GOOD
fas3050-31: /vol/vol2/lun7 /dev/sdf host20 iSCSI 2g (2147483648) GOOD
[root@dell67 log]# snapdrive snap disconnect -lun fas3050-31:/vol/vol4/lun2_20100513162059502_1
- LUN fas3050-31:/vol/vol4/lun2_20100513162059502_1 ... deleted
[root@dell67 log]# exit
logout
[root@dell67 dev]# exit
exit
[oracle@dell67 dev]$ exit
exit
SQL> l
1* select name, path from v$asm_disk
SQL> /
DG1_0000
/dev/raw/raw1
DG1
MOUNTED
[root@dell67 ~]# snapdrive storage show -dev
Connected LUNs and devices:
device filename adapter path size proto state clone lun path backing snapshot
/dev/sdc - P 50g iscsi online No fas3050-31:/vol/vol2/lun3 -
/dev/sde - P 2g iscsi online No fas3050-31:/vol/vol2/lun6 -
/dev/sdf - P 2g iscsi online No fas3050-31:/vol/vol2/lun7 -
/dev/sdg - P 3g iscsi online No fas3050-31:/vol/vol4/lun2
DG1_0000
/dev/raw/raw1
Did you try to execute manually?
raw /dev/raw/raw1 0 0
You have disconnected the lun, but the raw is there
I have create a snapshot for database orcl,
orcl use asm manage storage.orcl use DG1 for storage datafile, DG1's disk is /dev/raw/rwa1
/dev/raw/raw1 is belongs to product database orcl,and we should change /dev/raw/raw1's status .
now I want to mount the snapshot, using smo gui,
smo create device "/dev/sdd1 for the clone_lun,and mapping from disk "/dev/sdd1" to raw device "/dev/raw/raw11".
SMO change ASM Disk Group name in header of disk /dev/raw/raw11 from DG1 to DG1_20100514090543623_1
and mount ASM Disk Group DG1_20100514090543623_1
after the failer,smo disconnect device(s) [/dev/sdd] ,but not delete "/dev/raw/raw11
That is the reason that we need that you collect smo diagnostics
If SMO already renamed the diskgroup to DG1_20100514090543623_1 there is no reason to have duplicated id
Please collect the diagnostics for this operation and upload jar file
