Data Backup and Recovery
SMO mount error in oracle using ASM
bjloveunix
Hi,everyone,
     I have error in mount a error in oracle using ASM,  how  can i solve this problem?
--[ INFO] SMO-13046: Operation GUID ff8080812890c089012890c08dd20001 starting on Profile PROFILEASM
--[ INFO] SD-00028: Beginning to connect device(s) [/dev/sdg] from snapshot smo_profileasm_orcl_f_h_1_ff808081288f6c5801288f6c5dc20001_0.
--[ INFO] SD-00029: Finished connecting device(s) [/dev/sdg] from snapshot smo_profileasm_orcl_f_h_1_ff808081288f6c5801288f6c5dc20001_0.
--[ INFO] PLAT-00010: Creating mapping from disk "/dev/sdb1" to raw device "/dev/raw/raw10".
--[ INFO] ASM-00500: Changing ASM Disk Group name in header of disk /dev/raw/raw10 from DG1 to DG1_20100513162059538_1.
--[ INFO] ASM-00000: Mounting ASM Disk Group DG1_20100513162059538_1 on host dell67.
--[ERROR] FLOW-11019: Failure in ExecuteConnectionSteps: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100513162059538_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
ORA-15024: discovered duplicately numbered ASM disk 0
--[ERROR] FLOW-11010: Operation transitioning to abort due to prior failure.
--[ INFO] SD-00019: Discovering storage resources for all system devices.
--[ INFO] SD-00020: Finished storage discovery for all system devices.
--[ INFO] SD-00034: Beginning to disconnect device(s) [/dev/sdb].
--[ INFO] SD-00035: Finished disconnecting device(s) [/dev/sdb].
--[ WARN] FLOW-11011: Operation aborted
--[ERROR] FLOW-11008: Operation failed: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100513162059538_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ERROR] SMO-13032: Cannot perform operation: Backup Mount.  Root cause: SMO-11007: Error cloning from snapshot: FLOW-11019: Failure in ExecuteConnectionSteps: ORACLE-10003: Error executing SQL "ALTER DISKGROUP DG1_20100513162059538_1 MOUNT" against Oracle database +ASM: ORA-15032: not all alterations performed
--[ INFO] SMO-13039: Successfully aborted operation: Backup Mount
--[ERROR] SMO-13048: Backup Mount Operation Status: FAILED
--[ INFO] SMO-13049: Elapsed Time: 0:00:33.300
1 ACCEPTED SOLUTION
neto
Hi my friend
This is neto from Brazil
How are you?
Let me check the diagnostic file. Using SMO 3.0.2 and later ASMLib is not more a requirement.
I will double check the file and I back to you.
All the best
neto
24 REPLIES 24
neto
Hi
How are you?
Thank you very much. I will take a look, but would be great if you open a case with NetApp Global Support Center.
Please open and provide me the case number
All the best
neto
bjloveunix
Thanks,I will open a case later.
bjloveunix
Hi,neto
     I test mount and clone oracle database using asm.but use oracleasm  to create disk not use raw device.
mount and clone are sucessful.So I think smo for linux supports asm ,but must using asmlib .
neto
Hi my friend
How are you?
All the best
neto
