Data Backup and Recovery
Snap Creator Wrapper Script No Longer Works After Upgrade from 4.0p1 to 4.1P1
bcstorage
Greetings!  I recently upgraded my Snap Creator server from v4.0p1 to v4.1P1 in preparation for an OnTap upgrade from 8.1.2 to 8.2.1 7-mode.  Prior to the upgrade, we used a wrapper script to run an application consistent backup in our IBM FileNet environment.  We setup a Windows task to call the batch file each night and the job ran for approximately 3 - 4 minutes.  After the upgrade, we ran the job to verify that everything was working and it ran for about 15 seconds before Windows reported it was completed.  I checked the SC logs and there was no indication that the backup had run.  I was wondering if this could be related to the change to HTTPS.  My script is pretty basic so hopefully it doesn't require a lot to get it to work.  Here is an example of the .bat file we are trying to call:
rem Quiesce/Write suspend DB before backup of LUNs and CIFS
snapcreator.exe --user admin --passwd xxxxxxx --profile p8tst --config db2 --action quiesce --verbose --debug
rem Stop Verity Server service before backup of LUNs and CIFS
sc \\SMLP8TST3 stop "Verity K2 6.2.1 Administration Server"
rem Wait for Verity Server service to stop before running backup of LUNs and CIFS
          :while1
          sc \\SMLP8TST3 query "Verity K2 6.2.1 Administration Server" | findstr STOPPED
          if [%errorlevel%]==[1]          (
                    echo Still Running
                    PING 1.1.1.1 -n 1 -w 1000 >NUL
                    goto :while1
rem Backup CIFS and LUNS
snapcreator.exe --user admin --passwd xxxxxxx --profile p8tst --config cifs --action backup --policy daily --verbose --debug
rem Backup VMs
snapcreator.exe --user admin --passwd xxxxxxx --profile p8tst --config vm --action backup --policy daily --verbose --debug
rem UnQiesce/Write Resume DB
snapcreator.exe --user admin --passwd xxxxxxx --profile p8tst --config db2 --action unquiesce --verbose --debug
   rem Start Verity Server service
sc \\SMLP8TST3 start "Verity K2 6.2.1 Administration Server"
Could it be as simple as adding in the SC server name and specifying the HTTPS port?  I have tested all of the configs in the SC console and they all run correctly.  The only issue I am seeing is with my script that bundles them into a single job.  Any advice/assistance would be greatly appreciated.  I need to get this working quickly as the upgrade is happening this weekend.  Thank you in advance!
Bill
3 REPLIES 3
spinks
Bill,
Are you getting any error messages at all?
Do you pipe the output from the batch script somewhere you can check it?
Do you need to fully qualify your path to Snap Creator in your script?
If you don't provide the --server parameter then we will default to localhost.  If you don't provide --port then we will default to 8443.
When you say you tested the commands, can you confirm that you manually ran the same commands that are in the script through the Windows CLI?
I assume this is the case, but I wanted to be sure.
If there is any sort of error message we may be able to help more.
Thanks,
John
bcstorage
John,
I figured out the issue. When I ran the wrapper script from a cmd prompt
pointed to the SC installation directory, it ran as expected. After some
digging, we found a path setting in the server's environmental variables
pointing to the old version's location. Once we modified that, the job
ran from the task scheduler just fine.
Thanks for getting back to me. Your questions pointed me in a direction I
had not gone and ultimately got me to the solution.
I have one quick question that I was wondering if you could answer. As I
mentioned in the original post, we are upgrading to OnTap 8.2.1 7-mode
this weekend. I had gone through the interoperability matrix a few times
as we prepared for this upgrade to make sure we had all the right versions
installed. At one point, when I looked at Snap Creator, it appeared that
SnapDrive 7 was the only supported version for 8.2.1. I looked again
yesterday, and it now showed that SnapDrive 6.x was also supported. Can
you confirm if that is true? Otherwise, I still need to upgrade SnapDrive
from 6.5 to 7.
Thank you,
Bill Cook
Infrastructure Engineer
Security Mutual Life Insurance Company of New York
100 Court St.
P.O. Box 1625
Binghamton, NY 13902
607-338-7575
spinks
Bill,
Glad that helped
In regards to SnapDrive - Snap Creator does not have any dependency on SnapDrive, so I would guess that it is supported.
If SnapDrive is in the mix, we are typically calling SnapDrive via a Snapshot Create command in the Snap Creator config file.
If the IMT says it is supported, then that should cover it.
If it is missing we may need to ping our developers or QA and figure out if there is a reason why.
It could be that some other component in the mix has a SnapDrive dependency even if Snap Creator does not.
Hope this helps!
John
