Data Backup and Recovery
SnapCenter and SQL AvailabilityGroup
sanderbreur
Hi,
during install of SnapCenter 1.1 youve got the option "install local SQL express DB or use an existing SQL server/instance.
We have an SQL Availability Group (AG) so we chose the second option for a existing host.
Now, if we use the AG name with windows credentials install fails with error 1603 in the log.
If we do the same but use a nodename/instance of the same AG install finishes fine and DB is added to the node.
However, this is nog the way we want it because with a AG host failover DB's become stale.
So, is there a workaround to use the AG name during install?
2 REPLIES 2
Sahana
Hi,
Try using the cmdlet Add-SmBackupDataset  Refer https://library.netapp.com/ecm/ecm_get_file/ECMLP2440057
Refer page 8 Resources: For availability group backup @{"Host"="localhost";"Type"="SQL Availability Group";"Names"="AG1"} Valid Type values are: SQL Database, SQL Instance, SQL Availability Group. You can include comma-separated values for Names.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
neerajd
hi
