Data Protection
SnapCreator NFS mount options
jcbettinelli
Hello,
I'm trying to use the mount options with one of my customer. The volume is NFS.
I've used the parameters for the NFS, including export host, read-write or read-only, etc... but the command cannot mount automatically the volume.
It says that you need to add parameters for the mount command.
I've found the parameter called mount_cmd, but i don't know which syntax to use.
Documentation:
https://library.netapp.com/ecmdocs/ECMP1149421/html/html/GUID-4CE93A35-F2A3-4FA7-A8BF-3F86BEEB3FDE.html
The following table describes the mount and unmount commands:
MOUNT_CMD<##>
Mount commands are used to mount file system for cloning or mount actions, where ## is a number starting from 01-99.
UMOUNT_CMD<##>
Unmount commands are used to mount file system for cloning or mount actions, where ## is a number starting from 01-99.
Note: You should use MOUNT_CMDS and UMOUNT_CMDS for mount and unmount commands instead of Snap Creator PRE or POST commands for cloning.
Also, to notice, I've checked that the mount command has been added in the agent.conf file.
Can anyone help me with this ? I would really appreciate
1 ACCEPTED SOLUTION
ktenzer
I believe it is %SNAP_TIME
As far as use a variable for volume name, we dont have that capability yet.
Regards,
keith
6 REPLIES 6
sivar
MOUNT_CMD01=mount -F nfs -o rsize=32768,wsize=32768,vers=3,forcedirectio,bg,hard,intr,timeo=600,proto=tcp controller:/vol/cl_volumename1_%SNAPTIME /mountpoint1
MOUNT_CMD02=mount -F nfs -o rsize=32768,wsize=32768,vers=3,forcedirectio,bg,hard,intr,timeo=600,proto=tcp controller:/vol/cl_volumename2_%SNAPTIME /mountpoint2
Above is an example
Please follow your Operating System mount documentation and best practice guidelines
jcbettinelli
Hello Siva,
Thanks for your quick reply.
Is there a way to use a variable for the name of the volume ? I understand the %SNAPTIME, but how about the cl_volumename1. Should I replace this with the real volume name with cl_ as a suffix?
Thank you,
Jean-Christophe
sivar
Hello Jean,
Yes. you will substitute the volume name.
The example below will help further.
If your Profile name is SAP
If your config name is P40.conf
and if you are backing up (and cloning) the below volumes
/vol/SAP_DATA mounted as           /data
/vol/SAP_LOG mounted as            /log
/vol/SAP_ARCHIVE mounted as     /archive
then cloned volumes mount commands will be
MOUNT_CMD01=mount -F nfs -o rsize=32768,wsize=32768,vers=3,forcedirectio,bg,hard,intr,timeo=600,proto=tcp controller:/vol/cl_P40_SAP_DATA_%SNAPTIME /cl_data
MOUNT_CMD02=mount -F nfs -o rsize=32768,wsize=32768,vers=3,forcedirectio,bg,hard,intr,timeo=600,proto=tcp controller:/vol/cl_P40_SAP_LOG_%SNAPTIME /cl_log
MOUNT_CMD03=mount -F nfs -o rsize=32768,wsize=32768,vers=3,forcedirectio,bg,hard,intr,timeo=600,proto=tcp controller:/vol/cl_P40_SAP_ARCHIVE_%SNAPTIME /cl_archive
In other words,
/vol/cl_$configname_volumename_%SNAPTIME
jcbettinelli
Hello,
Thank again for your help.
I'll check with customer and I'll keep you updated.
Regards,
Jean-Christophe
ktenzer
Regards,
keith
sivar
Thank you Keith!
My bad.
Jean-Christophe,
Please use the syntax %SNAP_TIME
