Data Protection
SnapDrive Error: Class Not Registered
WebHousejoe
I installed SnapDrive 6.3 on a Windows 2008 server today and the installation was sucessful, but when i open the console and try to either create or connect a disk, i get a pop up that states:
SnapDrive Error:
Anyone ever run into this?
5 REPLIES 5
mjgalloway
Is this server part of a cluster? I ran into the same issue until I installed SnapDrive on the other node of the cluster.
WebHousejoe
Not sure what the issue was i guess sometimes it is a bad installation, if you uninstall and reinstall it actually works.
DEF__HEAD
Thanks mjgalloway
I had this same issue too until i read this post so thank you. Fix for me was install on both nodes before the create wizard apprears and works.
bholzmarsh
This worked for me as well.
serverbasic
