Data Protection
SnapVault using Qtrees
cferbrache
I can't seem to get SnapCreator to update my SnapVaults. I have existing SnapVault relationships. When I run it through the GUI it takes snapshots but doesn't update the SnapVaults.
fas6240d:/vol/d_did_001/did_001  fas3040a:/vol/dr_tix_001/did_001    Snapvaulted    627:15:09  Idle
fas6240d:/vol/d_dil_001/dil_001  fas3040a:/vol/dr_tix_001/dil_001    Snapvaulted    627:15:09  Idle
fas6240d:/vol/d_dir_001/dir_001  fas3040a:/vol/dr_tix_001/dir_001    Snapvaulted    627:15:09  Idle
fas6240d:/vol/d_dit_001/dit_001  fas3040a:/vol/dr_tix_001/dit_001    Snapvaulted    650:17:16  Idle
Here is the SnapVault section of my config.
### SnapVault Options ###
NTAP_SNAPVAULT_UPDATE=Y
SNAPVAULT_VOLUMES=fas6240d:/vol/d_did_001/did_001,/vol/d_dil_001/dil_001,/vol/d_dir_001/dir_001,/vol/d_dit_001/dit_001
SNAPVAULT_QTREE_INCLUDE=
NTAP_SNAPVAULT_RETENTIONS=daily:3
NTAP_SNAPVAULT_RETENTION_AGE=3
NTAP_SNAPVAULT_SNAPSHOT=Y
NTAP_SNAPVAULT_NODELETE=Y
NTAP_SNAPVAULT_RESTORE_WAIT=N
NTAP_SNAPVAULT_WAIT=
NTAP_SNAPVAULT_MAX_TRANSFER=20480
1 ACCEPTED SOLUTION
ktenzer
Yep issue here was snapvault relationships didnt exist on primary only secondary which can happen if you delete baseline snapshot on primary. Since Snap Creator goes first to primary to find secondary we got message that no relationships exist for given volume, which was 100% correct.
Thanks for the help all
Keith
9 REPLIES 9
ktenzer
Your syntax for SNAPVAULT_VOLUMES is not correct, it should be  SNAPVAULT_VOLUMES=<src filer>:<vol1,vol2,etc>
It us usually same as VOLUMES parameter, in your example something like
SNAPVAULT_VOLUMES=fas6240d:d_did_001,did_001,d_dil_001,etc
Also NTAP_SNAPVAULT_NODELETE =Y? This should be N unless you dont want SC to ever delete snapshots on secondary?
Please check AIG, the proper syntax is documented
Regards,
Keith
cferbrache
I tried that but then it said there was no snapvault relationship.
andrc
How about if you try one volume at a time and see if one in particular fails e.g.
Have you also checked that the SnapCreator server can resolve the controller hostname correctly?
cferbrache
Here are the new SnapVault settings:
SNAPVAULT_VOLUMES=fas6240d:d_did_001,d_dir_001,d_dil_001,d_dit_001,d_dia_001
NTAP_SNAPVAULT_SNAPSHOT=N
NTAP_SNAPVAULT_NODELETE=N
NTAP_SNAPVAULT_WAIT=60
NTAP_SNAPVAULT_MAX_TRANSFER=20148
Still getting this:
[Tue Jul 19 14:17:02 2011] DEBUG: ZAPI RESULT
<results status="passed"></results>
[Tue Jul 19 14:17:02 2011] INFO: NetApp Snapvault Status for fas6240d:d_did_001 finished successfully
[Tue Jul 19 14:17:04 2011] ERROR: [scf-00026] No Snapvault Relationship for fas6240d:d_did_001 exist! Exiting
And yes the SnapCreator server can resolve the controller hostname.
ktenzer
Your config is correct, well at least snapvault part is correct
Did you add fas3040a to NTAP_USERS? You need to add the secondary credentials, that is only thing I can think of, if they are missing you could get this error.
The error just means SC didnt find any relationships for volume on fas6240d, it is a configuration error somewhere.
What would help is seeing rest of config file and also the api results from snapvault-status, are we actually seeing your relationships? You can certainly investigate in the .out file SC creates further, lots of info there.
Keith
andrc
Does a `snapvault update` on the secondary complete successfully?
peter_lehmann
The error message gives you the answer...  this does not exist: fas6240d:d_did_001
You need to provide the full path with snapvault, because it is qtree related:
This will work.
Peter
ktenzer
Keith
cferbrache
After doing a "snapvault stop /vol/volume/qtree" on the secondary for all volumes. Then doing a "snapvault start -S primary:/vol/volume/qtree /vol/volume/qtree" on the secondary for all volumes I was then able to successfully do a snapvault update using SnapCreator.
Thanks to everyone for there help.
