Data Backup and Recovery
Snapcenter for MySQL Filesystem not supported
marcusgross
Hi,
we are running SC 4.3.1 to backup MySQL / MariaDB on Linux.
Agent is installed and running. MySQL resource was discovered but locked.
When choosing the credentials to unlock it, it fails with the message:
Failed - Failure in Filesystem plug-in discovery : [Filesystem '/' is a native file system and is not supported.] : <Hostname>
The database is running on NFS. Is there a way to trace the issue?
Marcus
6 REPLIES 6
Ontapforrum
Hi,  which *nix OS you are running, uname -a ?
pranjith
Can you check the datadir is on the Ontap storage?
"select @@datadir; "
marcusgross
Hi,
here it is:
MariaDB [(none)]> select @@datadir;
| @@datadir       |
| /var/lib/mysql/ |
the datadir points to a local FS. That seems to be the issue.
uname -a
Linux <Server> 3.10.0-1062.18.1.el7.x86_64 #1 SMP Wed Feb 12 14:08:31 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
pranjith
Yes. Please move the database to a Ontap Storage File system and then backup will go through.
Ontapforrum
Yes, Pranjith is absolutely correct. I remember adding few VMs to SnapCenter resource group sometime back and it complained 'un-supported' due to the fact that they were sitting on local-ds (non-netapp volume).
marcusgross
Hi,
they got in contact with the MariaDB support.
They stated that the database "should not run on NFS".
Is there a way of disabling the check of the filesystemlayout?
Marcus
