Data Backup and Recovery
Snapcreator Framework for Xenserver configuration issue
RAKESHMOLE2
Hi,
I am trying to install snapcreator framework 4.0 for Xenserver, however I am stuck on certain points
1) what does this option do "Take Xen VM Snapshots"
2)I have two host on the XEN pool, do I add them both
3) Where do I install the agent?
12 REPLIES 12
ktenzer
Hi,
Let me try to answer your questions
This is an option you want to set to take consistent snapshots of Xenserver VMs. If you dont set this option the NetApp snapshot taken is crash consistent which is normally fine, assuming you dont have application data inside VM which isnt being backed up by some other mechanism. What enable this option does is before we take NetApp snapshot we force Xenserver to create a meta data file for VM, writes then go to the meta data file and not the VM therefore the VM is now consistent. I am not a Xenserver expert but I believe this is the way it works. Someone correct me if I am wrong.
Not sure what a XEN pool is are these hosts VMs? Or are these hosts XEN servers?
If they are VMs then if you want to back them both up together yes, add them to config.
If they are XEN servers I think a backup config can only handle one Xenserver not multiple. You would need I believe one agent for each Xensserver and I dont think you can backup / restore a set of VMs on multiple Xenservers.
Agent should be installed on the host or a host which has the Xenserver management CLI. We use the CLI to create the metadata files and do things with the VMs.
Regards,
Keith
RAKESHMOLE2
Hi Keith
Xen pool is nothing but a pool of Xen hosts, when i was configuring it when i add one host i see all the VM's on it even though some of the VM's are not running on the other Xen server.
So should i be adding them both and if i have to add only one , what happens when the host that i added failed?
sivar
Hello Rakesh,
You can find the pool name by running the below command on the xenserver
xe pool-list | grep name-label | awk '{ print $4 }'
More information on the xen pool as borrowed from the link below.
http://knowledgelayer.softlayer.com/faqs/145
What is XenServer Pooling?
XenServer pooling can be thought of as up to 16 servers working as a cluster. This not only allows for shared resources but allows for live migration of VirtualMachines using XenMotion. One server will act as the "master node" while the rest of them will be slaves. Opening any of the servers in the pool via XenCenter will open the management information for the entire pool. When a node joins the pool its management password is changed to match the management password of the master node. When removing a node from the pool this password is not changed.  All systems in the node must be from the same processor family, as in Intel or AMD. You cannot have both Intel-based systems and AMD-based systems in the same pool as XenServer will not allow you to add them.  Ideally, hardware should be identical for pooling to be most successful. This is not entirely true with Heterogeneous CPU Pooling.  You will have to perform compatibility tests for yourself to see if your hardware is compatible.  Further inquiry should be directed to Citrix documentation:
http://support.citrix.com/article/CTX127059
RAKESHMOLE2
Hi keith/Shiva,
I finished the configration, however the job does not run, i get this error.
########## Detecting Data ONTAP mode for 10.99.2.201 ##########
########## Detecting Data ONTAP mode for 10.99.2.200 ##########
[2014-01-14 11:25:05,147] INFO: STORAGE-03031: System version details of [10.99.2.201].
[2014-01-14 11:25:05,147] DEBUG: <system-get-version/>
[2014-01-14 11:25:05,147] DEBUG: <system-get-ontapi-version/>
[2014-01-14 11:25:05,147] INFO: STORAGE-03032: System version details of [10.99.2.201] finished successfully.
[2014-01-14 11:25:05,568] INFO: STORAGE-03031: System version details of [10.99.2.200].
[2014-01-14 11:25:05,568] DEBUG: <system-get-version/>
[2014-01-14 11:25:05,569] DEBUG: <system-get-ontapi-version/>
[2014-01-14 11:25:05,569] INFO: STORAGE-03032: System version details of [10.99.2.200] finished successfully.
########## Agent validation ##########
[2014-01-14 11:25:05,936] INFO: Agent validation completed successfuly for agent Xenserver:9090
########## Plugin validation ##########
[2014-01-14 11:25:05,964] INFO: Plugin validation completed successfuly for plugin xen
########## PRE APPLICATION QUIESCE COMMANDS ##########
[2014-01-14 11:25:05,989] INFO: Pre application quiesce commands are not defined
########## PRE APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY  ##########
[2014-01-14 11:25:05,991] INFO: Application auto discovery is not enabled skipping .
[2014-01-14 11:25:05,991] INFO: Validate volume is not enabled skipping validate volume task.
########## Application Quiesce ##########
[2014-01-14 11:25:10,501] ERROR: SCF-00037: Application quiesce for plugin [xen] failed with error [javax.xml.bind.UnmarshalException
- with linked exception:
[javax.xml.bind.UnmarshalException: unexpected element (uri:"http://www.netapp.com/SnapCreator/Daemon/Agent", local:"value"). Expected elements are <{http://www.netapp.com/SnapCreator/Daemon/Agent}error_code>,<{http://www.netapp.com/SnapCreator/Daemon/Agent}preserved>,<{http://www.netapp.com/SnapCreator/Daemon/Agent}stderr>,<{http://www.netapp.com/SnapCreator/Daemon/Agent}env>,<{http://www.netapp.com/SnapCreator/Daemon/Agent}exit_code>,<{http://www.netapp.com/SnapCreator/Daemon/Agent}message>,<{http://www.netapp.com/SnapCreator/Daemon/Agent}stdout>]] and exit code [-1], Exiting!
########## Application Unquiesce ##########
[2014-01-14 11:25:10,724] ERROR: SCF-00032: Application unquiesce failed due to application error. Check logs and application settings. To ignore application errors and proceed with backup you can set APP_IGNORE_ERROR=Y.
sivar
This sounds like a known issue.
Please try installing/(upgrading) to Snap Creator Framework version 4.0p1 found here http://support.netapp.com/NOW/download/software/snapcreator_framework/4.0P1/
After installing 4.0p1 you may also add this variable in your config file
PLUGIN_RESULT_FILTERING_ENABLE=Y
Please let us know once you tried.
RAKESHMOLE2
Hi ,
I upgraded to 4.0P1, however it still does not work.
One more question.
I have contoller in 2040 HA pair and ontap is NetApp Release 7.3.6:
Does Snapcreator framework support it?
Also the command you suggested(PLUGIN_RESULT_FILTERING_ENABLE=Y), i added it under "application quiesce command" is that right?
[2014-01-15 16:38:28,898] INFO: STORAGE-03031: System version details of [10.99.2.201].
[2014-01-15 16:38:28,899] INFO: STORAGE-03032: System version details of [10.99.2.201] finished successfully.
[2014-01-15 16:38:29,343] INFO: STORAGE-03031: System version details of [10.99.2.200].
[2014-01-15 16:38:29,344] INFO: STORAGE-03032: System version details of [10.99.2.200] finished successfully.
[2014-01-15 16:38:29,362] INFO: Agent validation completed successfuly for agent XENHOST:9090
[2014-01-15 16:38:29,389] INFO: Plugin validation completed successfuly for plugin xen
[2014-01-15 16:38:29,391] INFO: Pre application quiesce commands are not defined
[2014-01-15 16:38:29,392] INFO: Application auto discovery is not enabled skipping .
[2014-01-15 16:38:29,393] INFO: Validate volume is not enabled skipping validate volume task.
[2014-01-15 16:38:29,608] ERROR: SCF-00037: Application quiesce for plugin [xen] failed with error [javax.xml.bind.UnmarshalException
[2014-01-15 16:38:29,825] ERROR: SCF-00032: Application unquiesce failed due to application error. Check logs and application settings. To ignore application errors and proceed with backup you can set APP_IGNORE_ERROR=Y.
sivar
Hello Rakesh,
Yes. ONTAP 7.3.6 is qualified against the 4.0.x version of Snap Creator Framework.
Please check the IMT support details below.
     Citrix XenServer 5.6 and 5.6FP1
     Citrix XenServer 6.0 and 6.0.1
     Only NFS is supported.
What OS is your Snap Creator Server running on?
If it is Windows, then try using a Linux server to run Snap Creator server.
What is the Snap Creator agent version?
(I see that you are using the linux agent directly on the xenserver. It is supported.)
Meanwhile, you may also try this?
Keep a separate Snap Creator server (preferably Linux)
Download and install XenCenter on a windows server http://support.citrix.com/article/CTX118531
Install Snap Creator Agent on the above mentioned windows server.
All the plugin does is to run xe commands. (In the above case "C:\Program Files (x86)\Citrix\XenCenter\xe.exe")
The xe command line interface is installed by default on XenServer Hosts. A stand-alone remote CLI (of xe) is also available for Linux and Windows.
Following parameters need to be in your config file.
### XEN Config Settings ###
# XEN_VMS - (required) semicolon separated <hostname:vm1,vm2> pair.                                     #
#           ie xenserver1:vm1,vm2;xenserver2:vm1,vm2                                                    #
# XEN_HOST_USERS - (required) semicolon seperated <hostname:username/password>                          #
#                  ie xenserver1:user1/password1;xenserver2:user2/password2                             #
# XEN_BIN_PATH - (required) Path of xe binary.                                                          #
#                ie C:\Program Files (x86)\Citrix\XenCenter\xe.exe                                      #
# XEN_METADATA_PATH - (required) Path on the server where we can store the vm metadata information      #
#                     ie C:\dir_name        #
# XEN_RESTORE_VMS  - (required only during restore) List of VMs to be restored.                         #
XEN_VMS=
XEN_HOST_USERS=
XEN_BIN_PATH=
XEN_METADATA_PATH=
XEN_RESTORE_VMS=
I am happy to jump on a webex. I am in Eastern time zone.
RAKESHMOLE2
Hi Siva,
To anwser your question
1) What OS is your Snap Creator Server running on?
I am runing the server and agenr on the server where i have installed the xencenter( it is windows 2008 R2).
Thats not the case here.
I am using the agent installed on the XEN center server.
This part is a concern for me :Only NFS is supported. as my all SR are iSCSI disks.
is there any netapp product like SMVI for XEN which supports SAN technology?
sivar
Hello Rakesh,
I have good news for you.
Snap Creator Framework 4.1 (expected to be released next week) will have support for iSCSI and FCP.
Please wait and read the Installation and Administration Guide (when released) as it has several pointers towards XEN backups and restore.
Thanks,
Siva Ramanathan
RAKESHMOLE2
Hi,
Unfortunately shiva it( snapcreator 4.1) supports only one vdi per lun, which i think is as good as no support at all.Anyways thats the way it is
mgeigel
Does anybody know if this will be changed in the future? I have the same problem at another customer. He has a lots of vdi files in one lun.
PIYUSHBANSAL198722
Hi,
I also have the same problem of multiple VDIs in one lun. But there is solution to it.. You could have the migration done either with the help of Citrix admin or yourself if you have root access on the xenserver pool master...
You could use "Move VM" options in you Xenserver (VM needs to be off/shutdown) and then select the new SR/lun you have already mapped to the xenserver...once it is done for all the VDIs then you would be able to perform the netapp based snapshots using snapcreator....
Also, If you are using iscsi SR then you should be able to take snapshots no problem...
Check your Ontap Compatibility with 4.1.1P3 snapcreator version and it should be flawless.....
Let me know if you face any issue....I have worked on it....but only with 7-mode....
