Data Backup and Recovery
Snapcreator rename cloned volume
francoisbnc
What will be the best way to customize cloned volumes rename after snapcreator flexclone if the default cl_ is not optimal.
Use POST_CLONE_CREATE_ CMD?
Help appreciate
François
2 REPLIES 2
sivar
François
I don't think we support renaming the clones.
1) you need ZAPIs to be executed, to rename the clones and SC does not allow you to put ZAPI commands there
2) NTAP_CLONE_IGROUP_MAP relies on cl_config_YYYYMMDDHHMMSS format to map luns - if you rename (by some other process), the clone_igroup_map may not work.
Thanks,
Siva Ramanathan
francoisbnc
I would like to refresh SAP/DB2 env DEV and QUAL, The DB2 plugins and consistent groups work very well. But I fear that leaving volumes with default name, with the number of instances, it will be quickly a mess.
Anyway I can create a very detailed config name.
