Data Protection
Data Protection
Hello,
I'm trying to take a snapshot on the primary and then snapvault it to the secondary. I've already created a snapvault relationship between the source and destination. All I want to do is run the backup, then SnapVault update to the secondary.
I'm getting the following error:
Snapvault may not work using IP address and it is not recommended
I've scanned in the controllers using IP address in SnapCreator. System Manager created the SnapVault relationships.
Solved! See The Solution
I am not very sure but his might be an issue with the host-name being in capital letters in the config and small letters on the controller.
This may be a bug in Snap Creator 4.0p1 but I will need to ask the Snap Creator team to verify.
I will check with them and in the mean time you can try replacing capital letters with small letters in the config file and let me know.
Thanks,
Kapil
Hi,
We don't recommend using IP addresses for configs with SnapVault or SnapMirror updates enabled.
But if you would still like to use them you can set ALLOW_IP_ADDR=Y in the configuration.
Thanks,
Kapil
Using IPs will only work if when you do snapvault status on controllers you also only see IPs.
SC cant translate IP to name yet
Regards,
Keith
Where is SnapCreator pulling this “Ip address from”. I created the SnapVault relationship through System Manager. Is it checking SnapCreator that it detects an IP address is being used or on the NetApp storage system itself. Can you point me in the right direction so that I can have it use the host name.
Regards,
Snap Creator is complaining because you are using IP address in your configuration files in NTAP_USERS parameter which stores controller credentials.
If you use only host-names in your configuration for both NTAP_USERS, VOLUMES and SNAPVAULT_VOLUMES parameter everything should work fine.
Kapil
SC simply looks at what controller name is in config parameters VOLUMES and SNAPVAULT_VOLUMES. Then it does snapvault status on secondary. It then compares, if it finds relationships for volume that match controller name from config and it does update if not it sends error that no relationships were found.
Keith
Thanks guys! I got past the initial problem.
I created a SnapVault relationship in System Manager and when I run the SC backup, it goes to perform a SnapVault update. When it runs, I get the following error:
I see the SnapVault relationship in an idle state in System Manager.
ERROR: SCF-00019: No Snapvault Relationship for :[vol_iso] exist! Exiting
Does SC automatically perform a SnapVault initialize? Should I have not created the relationship outside of SC?
It looks like it’s picking up the relationship.
Error log:
0:13:33,466] INFO: STORAGE-02110: Retrieving SnapVault status.
INFO: STORAGE-02111: Retrieving SnapVault status finished successfully.
INFO: Ignoring the snapvault relation with source hwducsnetapp01:/vol/vol_iso and destination ascnetapp1:/vol/SC_ISO/SC_ISO_sv with source status source
Please can you copy and paste the results of command 'snapvault status' on both primary and secondary controllers so that we can analyze the problem.
Thanks,
Kapil
Thanks!
Source:
hwducsnetapp01> snapvault status
Snapvault is ON.
Source Destination State Lag Status
hwducsnetapp01:/vol/vol_iso ascnetapp1:/vol/SC_ISO/SC_ISO_sv Source 03:17:18 Idle
hwducsnetapp01>
Destination:
ascnetapp1> snapvault status
Snapvault is ON.
HWDSMSP1:APPS-NC.HWDSMSP1.1381167154 ascnetapp1:/vol/NSB_HWDSMSP1/[HWDSMSP1]HWDSMSP1@APPS_ Snapvaulted 21:28:21 Idle
HWDSMSP1:.HWDSMSP1.1381167154 ascnetapp1:/vol/NSB_HWDSMSP1/[HWDSMSP1]HWDSMSP1@ Snapvaulted 21:28:30 Idle
HWDSMSP1:.HWDSMSP1.1381167154 ascnetapp1:/vol/NSB_HWDSMSP1/[HWDSMSP1]HWDSMSP1@ Snapvaulted 21:28:12 Idle
HWDSYNCSORT1:APPS-NC.NSB_MASTER.1381155594 ascnetapp1:/vol/NSB_MASTERSERVER/[NSB_MASTER]HWDSYNCSORT1@APPS_ Snapvaulted 24:41:10 Idle
HWDSYNCSORT1:.NSB_MASTER.1381155594 ascnetapp1:/vol/NSB_MASTERSERVER/[NSB_MASTER]HWDSYNCSORT1@ Snapvaulted 24:40:43 Idle
HWDSYNCSORT1:.NSB_MASTER.1381155594 ascnetapp1:/vol/NSB_MASTERSERVER/[NSB_MASTER]HWDSYNCSORT1@ Snapvaulted 24:41:01 Idle
HWDSYNCSORT1:.NSB_MASTER.1381155594 ascnetapp1:/vol/NSB_MASTERSERVER/[NSB_MASTER]HWDSYNCSORT1@ Snapvaulted 24:40:52 Idle
hwducsnetapp01:/vol/vol_iso ascnetapp1:/vol/SC_ISO/SC_ISO_sv Snapvaulted 03:17:49 Idle
This looks correct.
Are you still using IPs or you switched to hostnames?
Which version of Snap Creator is this?
Your NTAP_USERS should look something like this
NTAP_USERS= hwducsnetapp01:username/password;ascnetapp1:username/password
VOLUMES=hwducsnetapp01:vol_iso
SNAPVAULT_VOLUMES=hwducsnetapp01:vol_iso
is this correct?
If you still have IPs I would suggest replacing them with names and adding entry to etc/hosts or nameserver.
Thanks,
Kapil
When I was using IP addresses, I was getting an error earlier than this. Everything is configured via DNS now.
NTAP_USERS=HWDUCSNETAPP02:root/2f6778472f766f467536696548766c486a6752644d413d3d0a;HWDUCSNETAPP01:root/2f6778472f766f467536696548766c486a6752644d413d3d0a;HWDNETAPP1:root/724a75644e513068447370616c465437534e335961413d3d0a;HWDNETAPP2:root/724a75644e513068447370616c465437534e335961413d3d0a;ASCNETAPP2:root/724a75644e513068447370616c465437534e335961413d3d0a;ASCNETAPP1:root/724a75644e513068447370616c465437534e335961413d3d0a
SNAPVAULT_VOLUMES=HWDUCSNETAPP01:vol_iso
I verified there are no IP addresses. SC version 4.01p
Sorry, I meant to say everything is configured by hostname now. It is all resolvable and I fixed my DNS issues. Nothing is configured by IP address in SC.
Thanks,
Kapil
Thanks. Please let me know. I think so too… I am converting the names now.
Thanks for your help! It’s case sensitive. The issue happened because I scanned in the NetApp storage systems in System Manager using lower cased names. When I created the SV relationship in System Manager, it made those relationships in lower case. In SnapCreator, the NetApp storage systems were capitalized and couldn’t detect the relationship.
The update works now.
I am happy it finally worked for you.
I will raise a bug for 4.1 release if it is not already present.
Thanks for your patience.
Please close this thread if you don't have any more question.
Kapil
