Data Backup and Recovery
Volume backup speed is very slow by Networker
DIGWEED007
Hi, I have a problem with volume backup using networker.
Since long time ago, the volume(3) backup process takes 10 days to complete.
However, other volume backup such as volume(1)and(2) has better backup speed like 25MB/s.
This volume(3) has 2.73TB and average backup speed is 2000 to 5000 kb/s.
Here is the spec for our enviroment.
Backup target
NetApp Release 7.2.4P9
Volume 1 size 400 GB 10hours or less
Volume 2 size 200 GB 10hours or less
Volume 3 size 2.73 TB  takes 10days
Networker 7.6
OS:Windows 2003
Backup Storeage
Data Domain OS 4.9.2.6
I am new to these system but I need to be trouble-shoot immediately.
I've asked vendor support and thery are useless.
Please give me some advice, or if you more need information just let me know.
Sohei Tokui
5 REPLIES 5
dwaghmare
Hi Sohei,
You have not mentioned whether you are taking NDMP local backup or remote backup. Kindly mention the same.
Also check the utilization of NetApp storage using sysstat command. Asking this to check as NDMP is always backend process in all NAS devices, so if utilization of your device is higher then NDMP will get low priority.
DIGWEED007
Thank you for your quick response, I preciate your help
I've answered your qustion as follow,
-you mean the netwoker server is in same segment as Data Doman? Yes there are in same location.
-I have input the following command that I found in manual PDF and utilication is not the issue for this matter
We backup this volume during the night time only but sometimes during the day too, but it doesn't change much speed when it runs day or night.
sysstat -u -c 10 -s 2
CPU   Total    Net kB/s    Disk kB/s    Tape kB/s Cache Cache  CP  CP Disk
       ops/s    in   out   read  write  read write   age   hit time ty util
  1%      52  1323    85     24      0     0     0    46   96%   0%  -   1%
  1%      65  1316   366      0      0     0     0    46   99%   0%  -   0%
  1%      59  1317    58     18      0     0     0    46   97%   0%  -   0%
  4%     335  1020  9843   1348      0     0     0    44  100%   0%  T   2%
  4%     197  1069  1156   2450   7876     0     0    44  100%  35%  :   6%
  1%     191   776  1289     10      0     0     0    44   99%   0%  -   0%
  1%     183   889  1215      4      0     0     0    44  100%   0%  -   0%
  1%     159   776   830    310      0     0     0    44   96%   0%  -   1%
  1%     197   916  1143    436      0     0     0    44  100%   0%  -   1%
  3%     236   718   853   3218   6236     0     0    44   99%  34%  T  11%
Summary Statistics (   10 samples  2 secs/sample)
Min
  1%      52   718    58      0      0     0     0    44   96%   0%  *   0%
Avg
  1%     167  1012  1683    781   1411     0     0    45   99%   6%  *   2%
Max
  4%     335  1323  9843   3218   7876     0     0    46  100%  35%  *  11%
dwaghmare
Seems you are using DD as target for backup but it is not very clear whether you are using VTL feature of DD or you are backing up NetApp over LAN. Can you confirm the connectivity??
If you are backing up NetApp over LAN, that means NetApp will send data to backup server and server will write that data into DD appliance. In this case you will need to check your network settings, configuration, VLAN, and utilization etc.
DIGWEED007
We are not using VTL, just backing up by LAN.
Could you tell me the where I should check that you mentioned from last reply? what is the best configuration for network setting etc? what kind of configuration need to be input on DD or Netapp side to improve our system?
Thank you
DIGWEED007
Also Do you know any books that I can read to study regarding this matter? I try finding these related books but I cannot find any in Japan.
