Data Backup and Recovery
XenServer Restore Issue
vMarkus_K
Hi,
I`am running a test XenServer 6.0.2 witt 2 VMs:
CentOS
W2K9R2
SC 3.6.0.1 is uses on Windows 2008 R2
Backup seems to be working Fine (without error). But no restore is possible.
For me it semms to be a metadata Problem.
NFS Tree, including snapshot:
[root@localhost mnt]# tree -a
+-- 8a530fff-0047-ddde-ebe0-d827c131705e
¦   +-- aea97fc2-1856-4b51-a47e-c12e35ac7c47.vhd
¦   +-- f2aa92af-6f72-4af9-baab-4b1cc10f11af.vhd
¦   +-- filelog.txt
+-- fd9e028f-980c-d33b-7247-c71c4709d893
¦   +-- 02009757-f4a3-4f2a-84f1-e45adbecd9df.vhd
¦   +-- 048e5375-50ae-478b-b1e2-e950df272ee4.vhd
¦   +-- d3da9d9a-c664-46cd-bc8b-25a265bf1bf8.vhd
¦   +-- e4fb5af6-a172-4700-beff-bc8da16dc2d0.vhd
¦   +-- filelog.txt
+-- .snapshot
    +-- SC-daily_20121212121227
        ¦   +-- filelog.txt
            +-- 6cd5a5e4-f043-464f-9f28-e24f1f8bebe4.vhd
            +-- 7399c394-faf8-4a8a-b8fa-9b47fc60b8fc.vhd
            +-- 767720fe-9d7b-4178-8344-4c5bf6fbc895.vhd
            +-- b2ca4229-d599-4acc-a61b-d9bb9beb87f9.vhd
            +-- filelog.txt
6 directories, 20 files
W2K8 Metadata:
02009757-f4a3-4f2a-84f1-e45adbecd9df;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
b2ca4229-d599-4acc-a61b-d9bb9beb87f9;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
7399c394-faf8-4a8a-b8fa-9b47fc60b8fc;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
CentOS Metadata:
e4fb5af6-a172-4700-beff-bc8da16dc2d0;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
767720fe-9d7b-4178-8344-4c5bf6fbc895;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
6cd5a5e4-f043-464f-9f28-e24f1f8bebe4;fd9e028f-980c-d33b-7247-c71c4709d893;nfs;172.16.50.230:/vol/vol_xenserver_00
Restore LOG:
[Wed Dec 12 11:56:41 2012] INFO: Logfile timestamp: 20121212115641
[Wed Dec 12 11:56:41 2012] DEBUG: GMT - Wed Dec 12 10:56:41 2012
[Wed Dec 12 11:56:41 2012] DEBUG: Version: NetApp Snap Creator Framework 3.6.0
[Wed Dec 12 11:56:41 2012] DEBUG: Profile: vCenter
[Wed Dec 12 11:56:41 2012] DEBUG: Config Type: STANDARD
[Wed Dec 12 11:56:41 2012] DEBUG: Action: restore
[Wed Dec 12 11:56:41 2012] DEBUG: Application Plugin: xen
[Wed Dec 12 11:56:41 2012] DEBUG: File System Plugin: null
[Wed Dec 12 11:56:41 2012] DEBUG: Policy: daily
[Wed Dec 12 11:56:41 2012] DEBUG: Snapshot Name: SC-daily_20121212110920
[Wed Dec 12 11:56:41 2012] INFO: Plugin validation for xen completed successfully
########## Parsing Environment Parameters ##########
[Wed Dec 12 11:56:41 2012] DEBUG: Parsing VOLUMES - controller: 10.8.15.230 volume: vol_xenserver_00
[Wed Dec 12 11:56:41 2012] DEBUG: Parsing NTAP_USERS - controller: 10.8.15.230 user: root
[Wed Dec 12 11:56:41 2012] DEBUG: Parsing NTAP_SNAPSHOT_RETENTIONS - policy: daily retention: 3
########## Restore handling for plugin xen ##########
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Set environment variables successfully in xen plug-in
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Performing restore operation in xen plug-in
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Creating executor for the filer  10.8.15.230
[Wed Dec 12 11:56:41 2012] [10.8.15.202:9090(3.6.0.1)] DEBUG: Parsing NTAP_USERS - filer: 10.8.15.230 user: root
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Creating XEN RPC session on host : 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Getting the host instance and record information from host 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Found host with address 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Collecting host record information 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Host discovery completed successfully. Host address 10.8.15.206 with label xenserver-ipmeuedr
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Validating metadata file D:\XenServer_meta\xenserver-ipmeuedr_W2K8R2_SC-daily_20121212110920.metadata
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Reading the metadataFile D:\XenServer_meta\xenserver-ipmeuedr_W2K8R2_SC-daily_20121212110920.metadata
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Validating snapshot
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Checking VDI 8a530fff-0047-ddde-ebe0-d827c131705e/aea97fc2-1856-4b51-a47e-c12e35ac7c47 in snapshot 172.16.50.230:/vol/vol_xenserver_00/SC-daily_20121212110920
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [xen-00031] Not a valid snapshot. Not able to find aea97fc2-1856-4b51-a47e-c12e35ac7c47.vhd in snapshot SC-daily_20121212110920
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [xen-00032] Metadata file and snaphost information is not matching. W2K8R2
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: Restoring the VMs failed :10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: Restore operation failed for the host 10.8.15.206
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [scf-00006] Restore handling of plugin xen failed with exit code 1, Exiting!
[Wed Dec 12 11:56:44 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Set environment variables successfully in xen plug-in
[Wed Dec 12 11:56:44 2012] DEBUG: Application specific restore_cleanup operations are not yet implemented for plugin xen
[Wed Dec 12 11:56:44 2012] DEBUG: Exiting with error code - 1
Nachricht wurde geändert durch: Markus Kraus  Add debug log from snapshot
Nachricht wurde geändert durch: Markus Kraus Add metadata File
Nachricht wurde geändert durch: Markus Kraus add Restore Log
10 REPLIES 10
ktenzer
Are you using qtrees? In SC 3.6 XEN plugin wont work with qtrees, this will be fixed in next release of SC 4.0
Keith
charly
Yes agree with Keith. If SR is in qtree, restore won't work and same is fixed in SC4.0. Would be great if could send the xenserver-ipmeuedr_W2K8R2_SC-daily_20121212110920.metadata file.
Thanks
vMarkus_K
Hi,
I´am not using qtrees in this Test Enviroment.
charly
In that case, can you send us the metadata file. <name>.metadata ..?
vMarkus_K
metadata file is already attatched.
charly
sorry didn't notice that. Can you give the latest restore log also..? Please try to restore the snapshot SC-daily_20121212161024
vMarkus_K
Log is now attatched:
[Wed Dec 12 16:13:42 2012] INFO: Logfile timestamp: 20121212161342
[Wed Dec 12 16:13:42 2012] DEBUG: GMT - Wed Dec 12 15:13:42 2012
[Wed Dec 12 16:13:42 2012] DEBUG: Version: NetApp Snap Creator Framework 3.6.0
[Wed Dec 12 16:13:42 2012] DEBUG: Profile: vCenter
[Wed Dec 12 16:13:42 2012] DEBUG: Config Type: STANDARD
[Wed Dec 12 16:13:42 2012] DEBUG: Action: restore
[Wed Dec 12 16:13:42 2012] DEBUG: Application Plugin: xen
[Wed Dec 12 16:13:42 2012] DEBUG: File System Plugin: null
[Wed Dec 12 16:13:42 2012] DEBUG: Policy: daily
[Wed Dec 12 16:13:42 2012] DEBUG: Snapshot Name: SC-daily_20121212161024
[Wed Dec 12 16:13:42 2012] INFO: Plugin validation for xen completed successfully
[Wed Dec 12 16:13:42 2012] DEBUG: Parsing VOLUMES - controller: 10.8.15.230 volume: vol_xenserver_00
[Wed Dec 12 16:13:42 2012] DEBUG: Parsing NTAP_USERS - controller: 10.8.15.230 user: root
[Wed Dec 12 16:13:42 2012] DEBUG: Parsing NTAP_SNAPSHOT_RETENTIONS - policy: daily retention: 3
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Set environment variables successfully in xen plug-in
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Performing restore operation in xen plug-in
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Creating executor for the filer  10.8.15.230
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] DEBUG: Parsing NTAP_USERS - filer: 10.8.15.230 user: root
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Creating XEN RPC session on host : 10.8.15.206
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Getting the host instance and record information from host 10.8.15.206
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Found host with address 10.8.15.206
[Wed Dec 12 16:13:42 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Collecting host record information 10.8.15.206
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Host discovery completed successfully. Host address 10.8.15.206 with label xenserver-ipmeuedr
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Validating metadata file D:\XenServer_meta\xenserver-ipmeuedr_CentOS-neu_SC-daily_20121212161024.metadata
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Reading the metadataFile D:\XenServer_meta\xenserver-ipmeuedr_CentOS-neu_SC-daily_20121212161024.metadata
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Validating snapshot
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Checking VDI fd9e028f-980c-d33b-7247-c71c4709d893/e78f0a64-c723-4c56-908b-6a4492777db4 in snapshot 172.16.50.230:/vol/vol_xenserver_00/SC-daily_20121212161024
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [xen-00031] Not a valid snapshot. Not able to find e78f0a64-c723-4c56-908b-6a4492777db4.vhd in snapshot SC-daily_20121212161024
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [xen-00032] Metadata file and snaphost information is not matching. CentOS-neu
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: Restoring the VMs failed :10.8.15.206
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: Restore operation failed for the host 10.8.15.206
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] ERROR: [scf-00006] Restore handling of plugin xen failed with exit code 1, Exiting!
[Wed Dec 12 16:13:43 2012] [10.8.15.202:9090(3.6.0.1)] INFO: Set environment variables successfully in xen plug-in
[Wed Dec 12 16:13:43 2012] DEBUG: Application specific restore_cleanup operations are not yet implemented for plugin xen
[Wed Dec 12 16:13:43 2012] DEBUG: Exiting with error code - 1
charly
So the VM is having two disks right..?
vMarkus_K
No,
VM has only one disk.
But aufter Snapshot creation and removal I can see 2 vhd files per VM (2 VMs) in the original location.
[root@localhost /]# cd /mnt/fd9e028f-980c-d33b-7247-c71c4709d893/
[root@localhost fd9e028f-980c-d33b-7247-c71c4709d893]# ll
total 8731364
-rw-r--r--. 1 root root  981299712 Aug 19  2007 402b2cb9-6c71-439d-a3f6-2be21e9f6056.vhd
-rw-r--r--. 1 root root 1088638976 Aug 20  2007 8187ed66-8932-4112-afa7-3ffa23e7f6f9.vhd
-rw-r--r--. 1 root root 7480492544 Aug 19  2007 ae0e95a3-e62f-4596-a22d-0e458df4cabd.vhd
-rw-r--r--. 1 root root   59092992 Aug 20  2007 e78f0a64-c723-4c56-908b-6a4492777db4.vhd
-rw-r--r--. 1 root root       8856 Aug 19  2007 filelog.txt
[root@localhost SC-daily_20121212161024]# cd /mnt/.snapshot/SC-daily_20121212161024/fd9e028f-980c-d33b-7247-c71c4709d893/
total 8207324
-rw-r--r--. 1 root root      20992 Aug 19  2007 6bd0e5bf-f53f-4843-8bc2-dc4ecc52c062.vhd
-rw-r--r--. 1 root root    4526080 Aug 19  2007 8187ed66-8932-4112-afa7-3ffa23e7f6f9.vhd
-rw-r--r--. 1 root root      54784 Aug 19  2007 b5f78abb-061d-47e5-aa27-e1bf0ee6401c.vhd
-rw-r--r--. 1 root root      20992 Aug 19  2007 e78f0a64-c723-4c56-908b-6a4492777db4.vhd
XenServer Output:
[root@xenserver ~]# xe vdi-list name-label="W2K8R2-neu 0"
uuid ( RO)                : 8187ed66-8932-4112-afa7-3ffa23e7f6f9
          name-label ( RW): W2K8R2-neu 0
    name-description ( RW): Created by template provisioner
             sr-uuid ( RO): fd9e028f-980c-d33b-7247-c71c4709d893
        virtual-size ( RO): 25769803776
            sharable ( RO): false
           read-only ( RO): false
charly
Tried to reproduce this in our environment but not happening. The issue here is vdi-list API is giving two disks but actually only one disk present. This might be because some stale data. Is it possible to use your environment for some testing..?
You have two VMs here and both the VM restore behaves the same way..?
