Data Backup and Recovery
how OSSV configuration work on Snap Creator?
PINYOUUDK
As we know that in snap creator document mention about how enable OSSV and i try to follow document by set NTAP_OSSV_ENABLE=Y, NTAP_OSSV_HOMEDIR=/usr/snapvault. The OSSV relation already setup and initial baseline. but i didn't see any update data from OSSV relation whenever perform OSSV action in snap creator. What task i still not? or way to check?
1 ACCEPTED SOLUTION
ktenzer
Yep as I suspected VOLUMES is incorrect
You should only ever have primary volumes listed in SC config, never secondary volume for anything
Make following changes:
VOLUMES=linuxom:/boot
NTAP_USERS=Padma:pinyo/password
Regards,
Keith
12 REPLIES 12
ktenzer
Probably a configuration issue, format of VOLUMES is I am guessing issue.
1) please share your config file settings
2) ensure you have agent running and are using agent
3) ensure you have SC 3.5 or 3.6
Regards,
Keith
PINYOUUDK
Hi, here is my configuration file:-
CONFIG_TYPE=STANDARD
SNAME=testx
SNAP_TIMESTAMP_ONLY=Y
VOLUMES=172.32.0.57:pinyo_nfstest2
NTAP_SNAPSHOT_RETENTIONS=daily:0
NTAP_USERS=172.32.0.57:pinyo/password
NTAP_PWD_PROTECTION=N
TRANSPORT=HTTP
PORT=80
LOG_NUM=30
LOG_TRACE_ENABLE=Y
SC_TMP_DIR=
MANAGEMENT_INTERFACES=
SECONDARY_INTERFACES=
USE_PROXY=N
ALLOW_IP_ADDR=N
CMODE_CLUSTER_USERS=
CMODE_CLUSTER_NAME=
CMODE_SNAPSHOT_FORCE_DELETE=Y
NTAP_SNAPSHOT_RETENTION_AGE=
SNAPDRIVE=N
SNAPDRIVE_DISCOVERY=N
NTAP_SNAPSHOT_DISABLE=N
NTAP_SNAPSHOT_NODELETE=N
NTAP_CONSISTENCY_GROUP_SNAPSHOT=N
NTAP_CONSISTENCY_GROUP_TIMEOUT=medium
NTAP_CONSISTENCY_GROUP_WAFL_SYNC=N
NTAP_SNAPSHOT_DELETE_BY_AGE_ONLY=N
NTAP_SNAPSHOT_DEPENDENCY_IGNORE=N
NTAP_SNAPSHOT_RESTORE_AUTO_DETECT=Y
NTAP_SNAPVAULT_UPDATE=N
SNAPVAULT_VOLUMES=
SNAPVAULT_QTREE_INCLUDE=
NTAP_SNAPVAULT_RETENTIONS=
NTAP_SNAPVAULT_RETENTION_AGE=
NTAP_SNAPVAULT_SNAPSHOT=N
NTAP_SNAPVAULT_NODELETE=N
NTAP_SNAPVAULT_RESTORE_WAIT=N
NTAP_SNAPVAULT_WAIT=60
NTAP_SNAPVAULT_MAX_TRANSFER=
NTAP_SNAPMIRROR_UPDATE=N
NTAP_SNAPMIRROR_CASCADING_UPDATE=N
SNAPMIRROR_VOLUMES=
SNAPMIRROR_CASCADING_VOLUMES=
NTAP_SNAPMIRROR_WAIT=60
NTAP_SNAPMIRROR_USE_SNAPSHOT=N
NTAP_SNAPMIRROR_MAX_TRANSFER=
NTAP_VOL_CLONE_RESERVE=none
NTAP_LUN_CLONE_RESERVATION=false
NTAP_CLONE_IGROUP_MAP=
NTAP_CLONE_FOR_BACKUP=Y
NTAP_CLONE_SECONDARY=N
NTAP_CLONE_SECONDARY_VOLUMES=
NTAP_NUM_VOL_CLONES=0
NTAP_NFS_EXPORT_HOST=
NTAP_NFS_EXPORT_ACCESS=
NTAP_NFS_EXPORT_PERSISTENT=false
NTAP_PM_UPDATE=N
NTAP_DFM_DATA_SET=
NTAP_PM_RUN_BACKUP=N
NTAP_DFM_SNAPSHOT_FORMAT=
NTAP_OSSV_ENABLE=Y
NTAP_OSSV_FS_SNAPSHOT=N
NTAP_OSSV_FS_SNAPSHOT_CREATE_CMD01=
OM_HOST=
OM_USER=
OM_PWD=
OM_PORT=
OM_EVENT_GENERATE=N
ARCHIVE_CMD01=
MOUNT_CMD01=
UMOUNT_CMD01=
PRE_APP_QUIESCE_CMD01=
PRE_NTAP_CMD01=
PRE_NTAP_CLONE_DELETE_CMD01=
PRE_APP_UNQUIESCE_CMD01=
PRE_RESTORE_CMD01=
PRE_CLONE_CREATE_CMD01=
POST_APP_QUIESCE_CMD01=
POST_NTAP_CMD01=
POST_NTAP_DATA_TRANSFER_CMD01=
POST_APP_UNQUIESCE_CMD01=
POST_RESTORE_CMD01=
POST_CLONE_CREATE_CMD01=
NTAP_ASUP_ERROR_ENABLE=N
SENDTRAP=
SUCCESS_TRAP=
SUCCESS_MSG=INFO: Snap Creator finished successfully ( Action: %ACTION )
SC_AGENT=
SC_AGENT_TIMEOUT=60
SC_AGENT_UNQUIESCE_TIMEOUT=
SC_CLONE_TARGET=
SC_AGENT_WATCHDOG_ENABLE=Y
SC_AGENT_LOG_ENABLE=Y
APP_NAME=
FS_NAME=
APP_IGNORE_ERROR=N
APP_DEFINED_RESTORE=N
APP_DEFINED_CLONE=N
APP_AUTO_DISCOVERY=N
APP_CONF_PERSISTENCE=Y
VALIDATE_VOLUMES=
META_DATA_VOLUME=
JAVA_HOME=
JVM_ARGS=
JAVA_CLASSPATH=
PERL_HOME=
PERL_OPTS=
PYTHON_HOME=
PYTHON_OPTS=
ARCHIVE_LOG_ENABLE=N
ARCHIVE_LOG_RETENTION=1
ARCHIVE_LOG_DIR=/tmp/log
ARCHIVE_LOG_EXT=log
ARCHIVE_LOG_RECURSIVE_SEARCH=N
DB2_DATABASES=
DB2_CMD=/path/to/db2
MYSQL_DATABASES=
HOST=
PORTS=
MASTER_SLAVE=N
ORACLE_DATABASES=
SQLPLUS_CMD=/path/to/sqlplus
CNTL_FILE_BACKUP_DIR=/path/to/cntl_files
ORA_TEMP=/path/to/oratemp
ARCHIVE_LOG_ONLY=N
ORACLE_HOME=/path/to/orahome
ORACLE_EXPORT_PARAMETERS=Y
SME_PS_CONF=
SME_BACKUP_OPTIONS=
SME_SERVER_NAME=servername
SME_32bit=N
SYBASE_SERVER=
SYBASE_DATABASES=
SYBASE_DATABASES_EXCLUDE=
SYBASE_TRAN_DUMP=
SYBASE_TRAN_DUMP_FORMAT=
SYBASE_TRAN_DUMP_COMPRESS=Y
SYBASE_ISQL_CMD=/path/to/isql
SYBASE=/path/to/sybase
SYBASE_LOGDIR=/path/to/logs
SYBASE_MANIFEST=
SYBASE_MANIFEST_FORMAT=
SYBASE_MANIFEST_DELETE=Y
VIBE_VCLOUD_IPADDR=
VIBE_VCLOUD_USER=
VIBE_VCLOUD_PASSWD=
VIBE_VCENTER_USER=
VIBE_VCENTER_PASSWD=
VIBE_VCLOUD_NAMES=
VIBE_VSPHERE_NAMES=
SMSQL_PS_CONF=
SMSQL_BACKUP_OPTIONS=
SMSQL_SERVER_NAME=servername
SMSQL_32bit=N
DOMINO_DATA_PATH=
DOMINO_INI_PATH=
DOMINO_CHANGE_INFO_PATH=
DOMINO_DATABASE_TYPE=0
LOTUS=
Notes_ExecDirectory=
DOMINO_RESTORE_DATA_PATH=
POSTGRES_DATABASES=
PSQL_CMD=/path/to/psql
NO_PASSWORD_OPTION=Y
XUSER_ENABLE=N
HANDLE_LOGWRITER=Y
DBMCLICMD=/path/to/dbmcli
SQLCLICMD=/path/to/sqlcli
MAXDB_UPDATE_HIST_LOG=N
MAXDB_DATABASES=
MAXDB_CHECK_SNAPSHOT_DIR=
and below is my screen output when perform OSSV action. It show successed but data still not update.
[root@linuxom testx]# snapcreator --profile testx --action ossv --policy daily --verbose --debug
[Fri Jul 27 18:31:31 2012] DEBUG: Loaded Config File /opt/scServer3.5.0/configs/testx/testx.conf Successfully
[Fri Jul 27 18:31:31 2012] DEBUG: GMT - Fri Jul 27 11:31:31 2012
[Fri Jul 27 18:31:31 2012] DEBUG: Version: NetApp Snap Creator Framework 3.5.0
[Fri Jul 27 18:31:31 2012] DEBUG: Profile: testx
[Fri Jul 27 18:31:31 2012] DEBUG: Config Type: STANDARD
[Fri Jul 27 18:31:31 2012] DEBUG: Action: ossv
[Fri Jul 27 18:31:31 2012] DEBUG: Application Plugin: null
[Fri Jul 27 18:31:31 2012] DEBUG: File System Plugin: null
[Fri Jul 27 18:31:31 2012] DEBUG: Policy: daily
[Fri Jul 27 18:31:31 2012] DEBUG: Snapshot Name: testx-daily_20120727183131
[Fri Jul 27 18:31:31 2012] INFO: Logfile timestamp: 20120727183131
[Fri Jul 27 18:31:31 2012] INFO: Removing log testx.out.20120727125027.log
[Fri Jul 27 18:31:31 2012] INFO: Removing log testx.debug.20120727125027.log
[Fri Jul 27 18:31:31 2012] INFO: Removing log testx.stderr.20120727125027.log
########## Parsing Environment Parameters ##########
[Fri Jul 27 18:31:31 2012] DEBUG: Parsing VOLUMES - controller: 172.32.0.57 volume: pinyo_nfstest2
[Fri Jul 27 18:31:31 2012] DEBUG: Parsing NTAP_USERS - controller: 172.32.0.57 user: pinyo
[Fri Jul 27 18:31:31 2012] DEBUG: Parsing NTAP_SNAPSHOT_RETENTIONS - policy: daily retention: 0
########## PRE APPLICATION QUIESCE COMMANDS ##########
[Fri Jul 27 18:31:31 2012] INFO: No commands defined
########## PRE APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## APPLICATION QUIESCE COMMANDS ##########
########## APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## POST APPLICATION QUIESCE COMMANDS ##########
########## POST APPLICATION QUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## PRE NETAPP COMMANDS ##########
########## PRE NETAPP COMMANDS FINISHED SUCCESSFULLY ##########
########## PRE APPLICATION UNQUIESCE COMMANDS ##########
########## PRE APPLICATION UNQUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## APPLICATION UNQUIESCE COMMANDS ##########
########## APPLICATION UNQUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## POST APPLICATION UNQUIESCE COMMANDS ##########
########## POST APPLICATION UNQUIESCE COMMANDS FINISHED SUCCESSFULLY ##########
########## POST NETAPP COMMANDS ##########
########## POST NETAPP COMMANDS FINISHED SUCCESSFULLY ##########
########## ARCHIVE COMMANDS ##########
########## ARCHIVE COMMANDS FINISHED SUCCESSFULLY ##########
########## NetApp Snap Creator Framework 3.5.0 finished successfully ##########
[Fri Jul 27 18:31:31 2012] INFO: INFO: Snap Creator finished successfully ( Action: ossv )
[Fri Jul 27 18:31:31 2012] DEBUG: Exiting with error code - 0
[root@linuxom testx]# snapvault status
Snapvault primary is ON
Source         Destination                     State   Lag       Status
linuxom:/boot  Padma:/vol/pinyo_nfstest2/boot  Source  03:58:21  Idle
Regards,
Pinyo
ktenzer
Regards,
Keith
PINYOUUDK
Thanks Keith, you are right after i change as your mention. i fixed on linux.
anyway, how about in windows environment? if i want to set parameters VOLUMES for the path "WINDOWSCLI01
:C:\Program Files\IBM\Lotus\Domino"
i already set base line as below
C:\Program Files\netapp\snapvault\bin>snapvault status
WINDOWSCLI01:C:\Program Files\IBM\Lotus\Domino  Rowena:/vol/ossv_scg/Domino   Source  00:18:09  Idle
but when perform OSSV action, it still show [scf-00026] No Snapvault Relationship
########## PRE COMMANDS FINISHED SUCCESSFULLY ##########
[Fri Jul 27 09:11:21 2012] INFO: Getting Snapvault Status for WINDOWSCLI01:C:\"Program Files"\IBM\Lotus\Domino
[Fri Jul 27 09:11:21 2012] INFO: Running OSSV snapvault status command
[Fri Jul 27 09:11:21 2012] CMD: "C:/Program Files/netapp/snapvault"/bin/snapvault status
[Fri Jul 27 09:11:21 2012] [172.32.8.52:9090(3.6.0.1)] DEBUG: Command ["C:/Program Files/netapp/snapvault"/bin/snapvault status] finished with
exit code: [0]
stdout: [Snapvault primary is ON
WINDOWSCLI01:C:\Program Files\IBM\Lotus\Domino  Rowena:/vol/ossv_scg/Domino   Source  00:10:31  Idle
stderr: []
[Fri Jul 27 09:11:23 2012] ERROR: [scf-00026] No Snapvault Relationship for WINDOWSCLI01:C:\"Program Files"\IBM\Lotus\Domino exist! Exiting
########## Application unquiesce ##########
[Fri Jul 27 09:11:24 2012] [172.32.8.52:9090(3.6.0.1)] INFO: UnQuiescing databases
Regards,
Pinyo
jakob_bena
hello,
how can i set in the snap creator gui, schedules, under the point action "ossv". my only choice is snap, clone_lun or clone_vol.
regards
jakob
ktenzer
We only allow the three actions snap, vol_clone, or lun_clone to be scheduled.
Until we add more actions only thing you can do is not use SC scheduler for these or you can trick it. You could create a config and disable everything so no snapshot, etc. Then as APP_QUIESCE_CMD01 or any CMD really you could run SC with ossv as action. This requires two configs but would be a workaround.
I will ping dev and see what deal is and why we cant get more actions into scheduler
Keith
jakob_bena
thaks for your fast reply,
with two configuration it works.
regards
jakob
ktenzer
In addition I filed a bug with engineering so we will get this fixed soon so you can schedule ossv tasks
Sorry about that but glad workaround works
Keith
jakob_bena
an other point maybe is, if you try to configure a backup. there is no way to choose a server. you have to add first a filer for volumes and change your config via editor.
ktenzer
What do you mean choose a server? Just want to make sure I capture this correctly
Keith
jakob_bena
sorry for my late response.
if i make a new backup configuration, i have to setup first a source location. in a second step i can choose a snapvault/snapmirror destination.
the source location must be a netapp system, i can't choose a ossv server.
regards
jakob
ktenzer
Got it
Yeah OSSV is not possible to configure using wizzard you have to do it by hand
I think we can definitely add ability to add agent in future. So idea is SC will discover its agents and then if you have agent you can select it and we will do snapvault status through agent and then you can select a snapvault relationship.
I know we arent there yet but this would be possible in future
Keith
