Data Protection
sql Failed with error code 0xc0040827
bentdavi2
Hello
Can someone help, I have been getting this error , and I cannot find a solution.
I am running SMSQL backups and have been getting this error on mutiple DBs
Thank you
2 REPLIES 2
radek_kubka
Hi,
Have you seen this: http://communities.netapp.com/thread/15764?
There is "Failed to Get SnapInfo Directory from Registry" entry in your log, so running configuration wizard again will hopefully solve the issue.
Regards,
Radek
bentdavi2
Thanks , I will try that
Again thank you for the reply.
Best Regards
David Bentitou
480-766-3574
bentitou@us.ibm.com
