Compiling quota total commits to volume to then select Volume
JGPSHNTAP
We are working on workflows where the end state goal is to have WFA do the compiling of quotas on our utility volumes to check for oversubscription and then chose the proper volume.
Has anyone done something similiar to this?  If so, please share experiences.
The thought process is pull Volumes used size, total size and committed quotas and then go from there.
Any insight would be great.
Thanks
14 REPLIES 14
NICKBARTON
@JGPSHNTAP
You should have filters in place that can do most of this for you already. It's not clear what decision you are trying to get to though. Pick a volume for what? You mention quotas so are you talking for deploying new exports with user quotas?
We are using filters to determine where to deploy new volumes based on aggregate utililzation and overcommitement %, happy to help if I can just need to clarify what you are after.
-Nick
JGPSHNTAP
Nick,
I should have been more clear, i apologize if it was ambiguous.
So, we are doing deployment of what we are terming "general purpose" requests under 3TB to a dedicated utility volume.
So for example, the cluster will have 4 utility volumes.  As a request comes in, WFA calculates all the quotas committed, vol size used and then makes decisions on which volume to provision a  new qtree with new quota.  That is where we are heading.. Our DEV guys have made lots of progress on this in the past couple of days, by two methods, java or sql.
The challenge we are running into now is with the reserveation database.
Anything over 3TB, will get a dedicated volume.  The reason why we chose this design method is because of cluster vol limits and we realized that our provisioning was 80/20 rule.  Meaning 80% of our vols were <3TB.  Our Util vol starts at 10TB with autogrow max at 20TB.
We also feel this will help out more with SVM-DR and mirror'd volume limits.
I will gladly take some feedback and any info on forcing our commands into the reservation database would be great.
Thanks
joele
I've done similar queries in the past - I can send an example query over in the AM that might help.
JGPSHNTAP
That would be great.  We have working queries, but we are not happy with the timesync of WFA-OCUM and reservation data that isn't updating, so we are hoping to have a query that updates the reservation cache.
joele
JGPSHNTAP -
Sure, there can always be a few minute delay between WFA and OCUM that can make things a little tricky if you're doing frequent updates.
Is it just the quota create command that you need working reservations?  I can check if I have something written up for this already or not.
joele
I found a custom command I wrote awhile ago to create new qtree disklimit quotas.  The reservation and verification code seems to work from some quick testing I did this morning, probably something you'll want to test further though.
Reservation Code
UPDATE
    cm_storage.qtree, cm_storage.volume, cm_storage.vserver, cm_storage.cluster
SET
    qtree.disk_limit_mb = ('${QuotaSizeGB}' * 1024)
WHERE
    qtree.volume_id = volume.id
    AND volume.vserver_id = vserver.id
    AND vserver.cluster_id = cluster.id
    AND qtree.name = '${Qtree}'
    AND volume.name = '${Volume}'
    AND vserver.name = '${Vserver}'
    AND (
        cluster.name='${Cluster}'
        OR cluster.primary_address='${Cluster}'
Verification Code
SELECT
    qtree.id
FROM
    cm_storage.qtree,
    cm_storage.volume,
    cm_storage.vserver,
    cm_storage.cluster
WHERE
    AND qtree.volume_id = volume.id
    AND (
Let me know if you need any help with the custom command or anything here.  Happy to help take a look.
GidonMarcus
Hi
i believe i have exactly what you need, but in PS not as a query, i gave up on WFA for my project..... you can maybe try and take the logic... . it will order the volumes for you for where you have the most available space based on Quota allocation. volume free space, aggregate free space and aggregate on the snapmirror destination (if exists) free space. you can later filter the volumes you don't want to show (for example all the root ones, volumes that have the quota full etc)
Good luck
Gidi
Exemple:
These are the volumes we found fit to your reqest:
ID Dedupe SpaceBottleneck SpaceBottleneckname
 0   True 9.5TB           VolumeFreeSpace
 1   True 9.49TB          VolumeFreeSpace
 2   True 9.47TB          VolumeFreeSpace
 3   True 9.39TB          VolumeFreeSpace
 4   True 9.25TB          AggrFreeSpace
 5   True 8.93TB          TotalMinusQuota
 6   True 8.46TB          TotalMinusQuota
 7   True 8TB             TotalMinusQuota
 8   True 7.79TB          DRAggrFreeSpace
 9   True 7.72TB          TotalMinusQuota
10   True 7TB             TotalMinusQuota
11   True 6.22TB          TotalMinusQuota
12   True 5.48TB          TotalMinusQuota
13   True 5TB             TotalMinusQuota
14   True 3.88TB          VolumeFreeSpace
15   True 3.48TB          TotalMinusQuota
16   True 2.8TB           TotalMinusQuota
17   True 667.8GB         TotalMinusQuota
22   True -735846.4MB     TotalMinusQuota
please select a number from the list: 1
Selection made:
Name                      State       TotalSize  Used  Available Dedupe Aggregate                 Vserver
Test_vol          online        10.0 TB    5%     9.5 TB  True  Test_Aggr         Test_SVM
Code:
<# Created by Gidi Marcus FEB 2018 for http://community.netapp.com/t5/OnCommand-Storage-Management-Software-Discussions/Compiling-quota-total-commits-to-volume-to-then-select-Volume/m-p/137922#M25017
 Tested on:
 $CdotClustersSessions | select -First 1 Version; Get-Module DataONTAP | select version;$PSVersionTable.PSVersion.ToString();(Get-WmiObject -class Win32_OperatingSystem).Caption
Version
NetApp Release 9.1P6: Tue Jun 20 21:52:46 UTC 2017
4.1.0
5.1.14393.1737
Microsoft Windows Server 2016 Standard
Function Convert-BytesToSize
{[CmdletBinding()]
    Param([parameter(Mandatory=$False,Position=0)][int64]$Size)
    Switch ($Size){
        {$Size -gt 1TB}{
            $NewSize = “$([math]::Round(($Size / 1TB),2))TB”
            Break}
        {$Size -gt 1GB}{
            $NewSize = “$([math]::Round(($Size / 1GB),2))GB”
            Break}
        Default{
            $NewSize = “$([math]::Round(($Size / 1MB),2))MB”
            Break}
}Return $NewSize}
Function Select-FromOptions
    [CmdletBinding()]
    Param([parameter(Mandatory=$True,Position=0)]$OptionsList)
    While (-not $OptionSelected){
    $OptionSelected = $OptionsList[(Read-Host "please select a number from the list")]
    if ($OptionSelected)
        Write-Host -ForegroundColor "Green" "Selection made:"
        Write-Host ($OptionSelected | Format-Table | Out-String)
        break;
    else{Write-Warning "No valid selection made!, Please try again"}}
    Return $OptionSelected
function Get-CdotVars
    [CmdletBinding()]
    param($CdotClustersSessionss)
    $Results = @{}
    $Results.Aggregates = Get-NcAggr -Controller $CdotClustersSessions  -ErrorVariable errors
    $Results.Volumes = Get-NcVol -Controller $CdotClustersSessions  -ErrorVariable errors
    $Results.Vservers = Get-NcVserver -Controller $CdotClustersSessions  -ErrorVariable errors
    $Results.Qtrees = Get-Ncqtree -Controller $CdotClustersSessions  -ErrorVariable errors
    $Results.Quota = Get-NcQuota -Controller $CdotClustersSessions  -ErrorVariable errors
    $Results.Quotapolicy = Get-NcQuotapolicy -Controller $CdotClustersSessions -ErrorVariable errors
    $Results.SnapMirror= Get-NcSnapmirror -Controller $CdotClustersSessions  -ErrorVariable errors
    if($errors){
        $Results.Error = $errors
        Write-Error -message $Results.Error -Category InvalidData
        return $Results
    return $Results
function Get-CdotProdAplicableVolumes
    [CmdletBinding()]
    param($CdotVars,$CdotProdSVMs)
    $SVMAplicablePR = $CdotVars.Vservers | where Vserver -IN $CdotProdSVMs
    $Results = $CdotVars.Volumes  | where Vserver -in $SVMAplicablePR.vserver
    $Results | % {`
        $VolSelection_QuotaAllocated = [INT64](($CdotVars.Quota  | Where Vserver -eq $_.vserver |where Volume -eq $_.name | where DiskLimit -ne "-" | Measure-Object -property DiskLimit -sum).sum * 1024) #as NetApp not standarized it on our version
        $VolSelection_SanpMirror = ($CdotVars.SnapMirror | Where Policy -eq "DPDefault" | where SourceVserver -EQ $_.vserver | where SourceVolume -eq $_.name)
        $VolSelection_DRVolume = $CdotVars.Volumes | Where Name -eq $VolSelection_SanpMirror.DestinationVolume | where vserver -eq $VolSelection_SanpMirror.DestinationVserver
        $VolSelection_SpaceBottleneck = @{`
            "TotalMinusQuota" = ($_.TotalSize - $VolSelection_QuotaAllocated)
            "VolumeFreeSpace" = $_.Available
            "AggrFreeSpace" =  ($CdotVars.Aggregates | where name -eq $_.Aggregate).available
            "DRAggrFreeSpace" = ($CdotVars.Aggregates | where Name -eq $VolSelection_DRVolume.Aggregate).available
        $_ | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name QuotaAllocated -value $VolSelection_QuotaAllocated | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name TotalMinusQuota -value $VolSelection_SpaceBottleneck.TotalMinusQuota | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name AggrFreeSpace -value  $VolSelection_SpaceBottleneck.AggrFreeSpace |`
        Add-Member -MemberType NoteProperty -PassThru -force -Name DRSVM -value $VolSelection_SanpMirror.DestinationVserver |`
        Add-Member -MemberType NoteProperty -PassThru -force -Name DRVolume -value $VolSelection_SanpMirror.DestinationVolume |`
        Add-Member -MemberType NoteProperty -PassThru -force -Name DRController -value $VolSelection_DRVolume.NcController | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name DRAggr -value $VolSelection_DRVolume.Aggregate | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name DRAggrFreeSpace -value $VolSelection_SpaceBottleneck.DRAggrFreeSpace | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name SpaceBottlenecksize -Value (($VolSelection_SpaceBottleneck.GetEnumerator()  | Sort-Object -Property Value).Value | select -First 1) | `
        Add-Member -MemberType NoteProperty -PassThru -force -Name SpaceBottleneckname -Value (($VolSelection_SpaceBottleneck.GetEnumerator()  | Sort-Object -Property Value).Name | select -First 1)
$Cred = (Get-Credential -Message "login to clusters with Admin Accounts")
$CdotClustersSessions = Connect-NcController "Cluster1","Cluster2","Cluster3","Cluster4" -Credential $Cred -HTTPS -ErrorVariable errors # change clusters name name
$CdotVars = Get-CdotVars -CdotClustersSessions $CdotClustersSessions
$volumes = Get-CdotProdAplicableVolumes -CdotVars $CdotVars -CdotProdSVMs "ProdSVM1","ProdSVM2"   # Change SVM you conseider Prod
$Volumes = $volumes | ? name -notlike "*_root"  | Sort-Object SpaceBottlenecksize -Descending # exemple filter
Write-Host "These are the volumes we found fit to your reqest:"
$global:index=-1
Write-host ($volumes  | Format-Table -Property @{name="ID";expression={$global:index;$global:index+=1}},name,Dedupe,@{Expression={Convert-BytesToSize $_.SpaceBottlenecksize};Label=”SpaceBottleneck”},SpaceBottleneckname -AutoSize | Out-String)
$SelectedVolume = Select-FromOptions $volumes -ErrorAction Stop
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
JGPSHNTAP
Nice powershell.. Yeah, powershell is always easier, and we have mocked up code in powershell pretty easy.  We need to use WFA as we plan on sending REST calls from ServiceNow front-end to our customers.
for your convert to size, you can use Netapp's builtin convertto-formattednumber cmdlet.  That might do the trick as well.
joele
I also had this query - it's scoped at the SVM level but would be easy to expand.  Produces the following user input in a workflow:
Would something like this be useful?
JGPSHNTAP
Joele,
Yes, that would also be helpful.  We will share ours shortly and see what optimizations can be done.
We have figured out the reservation cache as well, just need to adjust our query
joele
Here's the query for the user input variable I've been using:
SELECT
    volume.name AS 'volume',
    ROUND (( (volume.size_mb * ((100 - volume.snapshot_reserved_percent) / 100)) / 1024 ),0 ) AS 'Total Volume Size (GB)',
    ROUND ((volume.used_size_mb / 1024),0) AS 'Used Volume Size (GB)',
    ROUND ((volume.available_size_mb / 1024),0) AS 'Available Volume Size (GB)',
    COUNT(qtree.id) AS 'Qtree Count',
    ROUND ((SUM(qtree.disk_limit_mb) / 1024),0) AS 'Quota Allocated (GB)'
FROM
    cm_storage.volume as volume,
    cm_storage.vserver as vserver,
    cm_storage.cluster as cluster,
    cm_storage.qtree as qtree
WHERE
    AND qtree.name != ''
    AND volume.name NOT LIKE '%_root%'
    AND vserver.name = '${VserverName}'
    AND (
        cluster.name = '${ClusterName}'
        OR cluster.primary_address = '${ClusterName}'
GROUP BY
    volume.id
ORDER BY
Curious to see what you've been working on around the cache query.  Have a good one!
JGPSHNTAP
Ok, here is our query the team has wrote, and could use some advice on this.
SELECT
    cv.id,
    cv.name AS 'name',
    cv.used_size_mb AS 'used',
    cv.size_mb AS 'total_size',
    vserver.name AS 'vserver.name',
    cluster.primary_address AS 'vserver.cluster.primary_address',
    (((SELECT
        sum(qtree.disk_limit_mb)
    FROM
        cm_storage.qtree
    WHERE
        qtree.volume_id = cv.id )/cv.size_mb)*.5 + (cv.used_size_mb/cv.size_mb)) AS 'Averaged'
FROM
    cm_storage.volume cv,
    cm_storage.vserver,
    cm_storage.cluster
WHERE
    cv.security_style = '${security_style}'
    AND cv.used_size_mb / cv.size_mb < .90
    AND cv.name LIKE '${VolPrefix}%'
    AND vserver.id = cv.vserver_id
    AND cluster.id = vserver.cluster_id
    AND vserver.name NOT LIKE '%_dr'
    AND          (
        cv.size_mb * 2 > (
            SELECT
            FROM
                cm_storage.qtree
            WHERE
        OR cv.used_size_mb = 0
ORDER BY
    Averaged ASC
We have to do same subquery 2x to reference.
For reservations we had to go to commands we defined mandatory variables
  [parameter(Mandatory=$false, HelpMessage="Disk Limit")]
  [long]$disk_limit_mb,
  [parameter(Mandatory=$false, HelpMessage="Disk Soft Limit")]
  [long]$disk_soft_limit_mb
Added parameter defintions, add parameter mappings, and then in reservation tab
added this
'${disk_limit_mb}' AS disk_limit_mb, -- Default value for disk limit, soft disk limit and filelimit is 0
'${disk_soft_limit_mb}' AS disk_soft_limit_mb,
Now that updates the reservation table.
Thanks for checking our query
GidonMarcus
Hi @joele
can you share ther query you used for this table ?
G
joele
Hi Gidon,
The SQL query syntax is a few posts up for that table, here's a direct link:
https://community.netapp.com/t5/OnCommand-Storage-Management-Software-Discussions/Compiling-quota-total-commits-to-volume-to-then-select-Volume/m-p/13...
Hope this helps and let me know if you have questions.
Joel
