DFM reporting issue
TOLGAASIK
Hello;
I have installed and configured UM Core Package 5.2 on Windows Server 2008 R2 with SP1. I have excluded the extensions/folder and applications(exe) of DFM on Symantec AV.
I am trying to share any report. It is showings the following error:
"Unable to share the report: Could not run the report storage-systems-report(36). Please refer dfm and dfm server logs for more detailed information.
I checked the dfm server log and I saw the following error :
Feb 12 17:01:55 [dfmserver: INFO]: [2260:0xbe8]: Checking local groups for user Domain\username: Windows account "username" does not exist on system "DFM_Host_Name".
Feb 12 17:01:55 [dfmserver:ERROR]: [2260:0xbe8]: http_open_url_socket failed with return value -5. Please validate dfm http and webui services are running correctly.
Other informations:
OS :     Microsoft Windows Server 2008 R2 Service Pack 1 (Build 7601) x64 based
Data ONTAP Operating Mode: 7-Mode
Version : 5.2.0.16233 (5.2)
Browser : Firefox 19
Is there any idea?
1 ACCEPTED SOLUTION
TOLGAASIK
Hello,
Ultimately, I have solved the issue. After DFM installed, I had disabled the HTTP  connection for unsecure connection, only HTTPS is active. Probably DFM uses http connection for internal communication. I have enabled HTTP , the problem was solved. Now I can share/export any reports.
Commands are below to this issue :
dfm option set httpEnabled=Yes
dfm service stop webui
dfm service start webui
dfm service stop http
dfm service start http
Best Regards.
3 REPLIES 3
kryan
Hi,
  1. Are you noticing any other errors or odd behavior?
  2. Has this behavior occurred since you installed UM 5.2?
  3. When did you notice the behavior for the first time?
Please open a support case and refer to Bug 747520.  You will want to include a DFMDC output to provide the UM logs.
Thanks,
Kevin
TOLGAASIK
Hi Kevin,
  1. I don’t see any errors or odd behavior except reporting.
  2. I have installed UM 5.2 newly not upgrading.
  3. After it has been installed.
Ok, I will open a case. Thanks.
TOLGAASIK
Hello,
Best Regards.
