Data Infrastructure Management Software Discussions
Highlighted
EMC clariion CLI using navisphere
Hi.
My problem is that teh data source is coming back saying :
Can not parse disk
What does that mean ?
Am i missing something in the New_diskmodel file?
What is wrong.
Version 6.4.1 with  with the latest sp on .
Regards
Joans
5 REPLIES 5
Re: EMC clariion CLI using navisphere
Hey Jonas,
Can you right click the datasource -> Create Support Report, and send me the resulting file at ostiguy at netapp dot com ?
I am not seeing any hits in our bugs database for "Can not parse disk"
Hi Matt.
How do i sent it over , its 25 mb.
Mvh/Regards
Jonas Enhörning
Duke Systems AB
Tel +46 8 765 48 80
Från: ostiguy
Skickat: den 7 november 2013 14:28
Till: Jonas Enhörning
Ämne: - Re: EMC clariion CLI using navisphere
<https://communities.netapp.com/index.jspa>
created by ostiguy<https://communities.netapp.com/people/ostiguy> in OnCommand Insight - View the full discussion<https://communities.netapp.com/message/120138#120138>
Hey Jonas,
Reply to this message by replying to this email -or- go to the message on NetApp Community<https://communities.netapp.com/message/120138#120138>
Start a new discussion in OnCommand Insight by email<mailto:discussions-community-products_and_solutions-storage_management_software-oncommand--insight@communities.netapp.com> or at NetApp Community<https://communities.netapp.com/choose-container.jspa?contentType=1&containerType=14&container=3203>
If you have 7zip installed, open the zip with 7 zip, navigate to the "acq" folder, and pluck the foundation_XYZ...zip out of that folder - it should be much much smaller.
That foundation_xyz....zip , where XYZ is your datasource name,is the actual datasource recording, which is probably all I need
Or go to https://upload.netapp.com/hq/Userfile.  Enter Matt's email when it asks for an email address.  When it arrives he'll be sent an email with a URL where it can be downloaded.
Engineering actually already has cooked up a patch for Jonas.
The Clariion / VNX for block seems to have a defined RAID group with no disks that are part of it. The patch will skip over such a RAID group, but we are curious to know if the customer knows the history of it
Forums
