Data Infrastructure Management Software Discussions
Highlighted
First LDAP connection failed then works...
Hello,
I have a strange problem with all my 5 WFA servers connected to Active Directory for authentication.
When a user try to log on for the first time since the browser was open, the authentication failed with the message : "The username or password is incorrect"
If the user retry one more time, the authentication works fine.
I have the same problem on different servers connected to different domains. All are Windows 2008 R2.
THe logon failure generates the following message on the server.log (nothing on wfa_ldap.log) :
2013-04-08 17:45:29,603 BST ERROR [org.jboss.web.tomcat.security.JBossWebRealm] (http-0.0.0.0-80-4) Error during authenticate
java.lang.IllegalStateException: Security Context has not been set
at org.jboss.web.tomcat.security.SecurityAssociationActions$SetPrincipalInfoAction.run(SecurityAssociationActions.java:70)
at java.security.AccessController.doPrivileged(Native Method)
at org.jboss.web.tomcat.security.SecurityAssociationActions.setPrincipalInfo(SecurityAssociationActions.java:270)
at org.jboss.web.tomcat.security.JBossWebRealm.authenticate(JBossWebRealm.java:388)
at org.apache.catalina.authenticator.FormAuthenticator.authenticate(FormAuthenticator.java:258)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:417)
at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:92)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.process(SecurityContextEstablishmentValve.java:126)
at org.jboss.web.tomcat.security.SecurityContextEstablishmentValve.invoke(SecurityContextEstablishmentValve.java:70)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java:158)
at org.apache.catalina.authenticator.SingleSignOn.invoke(SingleSignOn.java:383)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:330)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:829)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:598)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:722)
Any help will be appreciated.
Thanks,
Julien
24 REPLIES 24
Highlighted
Re: First LDAP connection failed then works...
I am also experiencing this issue. Hopefully somebody from the WFA team can provide some insight on how to resolve this.
Highlighted
Hi Julien and Dan,
     I'm unable to reproduce the problem with the information you have given. Can you provide a bit more detail into this?
1. What the are login attributes you are using? Are they same as what's provide in default setup?
2. How are you trying to login? Is it by "DOMAIN\username" or just "username"
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Highlighted
Hello sinhaa,
1. My configuration uses 2 Active Directory servers with FQDN name. I tried with IP address with no luck. (Screen capture attached). Servers are separated by comma.
2. We are using DOMAIN\username to login.
Thanks,
Julien
Highlighted
Nothing looks wrong here. But with similar configuration, I'm still unable to hit this problem. I need some more information.
Does it happen all the time? I mean every single time you try to login as an LDAP user, the first attempt will necessarily fail and the second one will pass. Is this correct?
Does it happen for all the users or a users in a specific WFA User group?
What browser are you using? Do you suspect any old browser cache causing it perhaps? Clear browser cache and try.
Is you LDAP configured over SSL?
Highlighted
What version of Jboss does WFA run?
OnCommand Insight had something similar. Ultimately the fix was to tweak the login-config.xml file
Highlighted
Yes, this happens all the time.
We have only two types of users Admin and Operator and we have the problem on both.
We are using Internet Explorer 8.0.7601.17514 & 9.0.8112.16421 and Firefox 17.0.1
I still have the problem when clearing the browser cache.
Yes my AD is configured for SSL
Thanks,
Julien
Highlighted
Looks to be JBoss 5.1.0.GA according to the Release Notes installed..
Highlighted
Hi Sinhaa,
1. Login Attributes ->
2. We are logging in using "DOMAIN\username"
This issue happens every single time a user logs in.
Thanks,
Dan
Highlighted
Hi ostiguy,
     Can you suggest what tweak was required to be done?
Highlighted
I believe the fix for OCI was to switch the order of login modules in login-config.xml.
If someone could email me ( ostiguy at netapp dot com ) their login-config.xml, I could take a look and offer a suggestion
Highlighted
Hi Ostiguy,
I'll send you config file.
Thanks,
Sasha
Highlighted
Hi Dan, Julien and jmalghem2009
I've created custom login module configuration as per ostiguy suggestion.
Please send me your mail if you want to try it and I'll send you the instructions.
My mail is: korman at netapp dot com
Thanks,
Sasha
Highlighted
Interesting that OCI has been mentioned. I see similar behavior with my OC Report instance, which basically uses the same engine as OCI.
And I too have seen it with my WFA installation, but it appears to occur randomly.
regards, Niels
Highlighted
I also sent you an email with my current WFA "login-config.xml" config file.
Thanks!
Dan
Highlighted
Having the exact same problem here.  Did anyone ever find a solution?  First login attempt via LDAP/AD fails every time.  Second attempt is OK.
Thanks,
Craig
Try the NEW Knowledgebase!
NetApp KB Site
Forums
