Data Infrastructure Management Software Discussions
Highlighted
How to create a volumeFull alarm with severity as critical for a specific group
Hello All,
We have some requirements for DFM alert as follows.
* VolumeFull alert for SAP volumes should show as critical event with threshold 85%.
I have set the volumeFull threshold to 85% but I need to set the severity as critical for the SAP volume group .
If I am setting the severity for the VolumeFull as critical it sets for the Global , but I want it to be set only for SAP volumes.
2 REPLIES 2
Re: How to create a volumeFull alarm with severity as critical for a specific group
Not sure if this is a support related issue.  , is this something your team handles?
Mike
Hi,
If you have a NOW login you can check to see if this is covered by this Knowledgebase article.
If that does not provide what you need, use your NOW login and ask the question in the Data ONTAP area in the NetApp Support Community where we have external and internal subject matter experts providing answers.
Mike
Forums
