Data Infrastructure Management Software Discussions
Highlighted
How to fix "Long running collector for STATISTICS"
Recently got an error on my Insight  Balance console that told me that my I had a Long running collector for STATISTICS:XXX.XXX.XXX.XXX.
Cant find any details on how to remedy this fault - anyone got any suggestions ?
Regards,
Richard
9 REPLIES 9
Highlighted
Re: How to fix "Long running collector for STATISTICS"
Pls turn OFF the following option  in your Storage Systems.
nfs.per_client_stats.enable
cifs.per_client_stats.enable
Regards
adai.
Highlighted
Thanks Adai,
Have checked both those options and they are both off.
Is there anyway to identify and "kill" this process  on the filer that does not involve shutting it down ?
Regards,
Richard
Highlighted
Hi Richard,
     Are you using Performance Adviser 4.0 or latter which support client stats ? But AFAIK PA does not collect client stats more than 90/60 seconds.Also have you enabled automated client stats collection in PA/DFM ? If so what is the version of your DFM.
Regards
adai
Highlighted
Hi Adai,
We are running OnCommand  Balance Version 4.0.0.1 and  OnCommand/DFM  5.0.1
autoClientStatEnabled is set to  No
Regards,
Richard
Highlighted
Hi Richard,
    AFAIK, these are things that trigger client stats. I don't know of anything other which triggers. I suggest you to work with support to nail down the issue.
Regards
adai
Highlighted
Were you able to find a resolution?
Highlighted
Not as yet , not worried too much as I am about to retire that storage system
Highlighted
This is a late reply, but if it only happened once, there is no need for concern. If it is repeating, you can reboot the Balance VA, and it should clear up.
If it continues after a reboot, please give support a call.
Regards,
Peter
Highlighted
       Thanks  - yes I done that
Try the NEW Knowledgebase!
NetApp KB Site
Forums
