How to replace FAS3270 Controller with FAS6240 Controller?
ferianto_siregar85
Dear Experts,
Can anybody help me about the procedure (step by step) how to replace FAS3270 Controller - HA Cluster with new one FAS6240 Controller (HA) ? and how about data? do this replacement cause the data on disk shelf (data aggr (aggr1)) overwritten?
Kindly need your suggestion , please?
Thank you
--feri-
1 ACCEPTED SOLUTION
radek_kubka
Hi and welcome to the Community!
You can find this document useful ad well:
https://communities.netapp.com/docs/DOC-12356
Regards,
Radek
4 REPLIES 4
bernd_wolters
The painpoints are:
  • Same Ontap-Release on source and destination
  • root volume size
  • check LUN Serials
  • check Nodenames
  • Disk reassignment
  • Mailbox destroy local / Mailbox destroy partner
No Data is overwritten!
The procedure is quite simular to the following article:
http://support.netapp.com/NOW/knowledge/docs/hardware/NetApp/cs_migration/FAS3xxx/FAS3040-FAS3070_to_FAS32xx_HA-pair/GUID-6C3427B1-F6EA-4143-9579-FEF8...
I have not found an "Upgrade Guide" from 32xx to 62xx but the workflow is very simular
Regards Bernd
ferianto_siregar85
Thank you for your help, Bernd...It is really helpful....
radek_kubka
Regards,
Radek
ferianto_siregar85
Thank you for your help, Radek...It is really helpful....
Greatttt....Thank you very much....
