Is Volume AutoSize State cached in WFA for 7-Mode
adaikkap
Hi,
      We are trying to create a filter and run a workflow for all volumes where the volumes current size is greater than the volumes Max size.
Basically, trying to catch the list of volumes which have grown beyond the autogrow maximum  even though autogrow is enabled.
In the current storage schema, dont find the autogrow state. Or should rely on the autosize_max and increment_size and interpret autogrow is not enabled if these values are Null ?
Terminology:
Max size: Auto Grow Maximum size
Current Size: Volumes current size returned by df.
Regards
adai
1 ACCEPTED SOLUTION
shailaja
Hi Adai,
In the WFA cache, the following two attributes are filled only when autogrow is enabled on the volume. Otherwise they will have a NULL value.
1. autosize_max_mb
2. autosize_grow_mb
Thanks,
Shailaja
2 REPLIES 2
shailaja
Hi Adai,
1. autosize_max_mb
2. autosize_grow_mb
Thanks,
Shailaja
adaikkap
Hi Shailaja,
           Thanks, thats what we thought and wanted to confirm if its a right assumption. Is this documented somewhere in the WFA so that users are sure and don't think that there is no information on the volume being autogrow enabled or not.
Regards
adai
