Data Infrastructure Management Software Discussions
Highlighted
Is it possible to create threshold for domain utilization?
Hello,
I'm trying to create performance threshold for domain utilization in OC5 but it looks like it's not supported.
Or am I doing something wrong?
Genericmonitoring:~ # dfm perf threshold create -o MONITORED -d 300 -e perf_cpu -C "processor:domain_busy:kahuna 80 percent"
Error: Invalid counter: "processor:domain_busy:kahuna".
Syntax is obj-type:counter-name.
Genericmonitoring:~ # dfm perf threshold create -o MONITORED -d 300 -e perf_cpu -C "processor:domain_busy 80 percent"
Error: Could not create threshold.
Reason: Invalid threshold specification: Label X not provided for counter processor:domain_busy.
Genericmonitoring:~ # dfm perf threshold create -o MONITORED -d 300 -e perf_cpu -C "processor:processor0:domain_busy 80 percent"
Error: Invalid counter: "processor:processor0:domain_busy".
Genericmonitoring:~ # dfm perf data retrieve -d 300 -C processor:domain_busy:kahuna -o hamster
I am able to retrieve the performance data:
Timestamp       hamster:processor1:domain_busy:kahuna
2012-03-20 12:20:57     5.159
2012-03-20 12:21:57     3.251
2012-03-20 12:22:57     4.485
2012-03-20 12:23:58     4.282
Timestamp       hamster:processor0:domain_busy:kahuna
2012-03-20 12:20:57     6.204
2012-03-20 12:21:57     6.016
2012-03-20 12:22:57     6.921
2012-03-20 12:23:58     7.062
Creating other thresholds works fine:
Genericmonitoring:~ # dfm perf threshold create -o MONITORED -d 300 -e perf_cpu -C "system:avg_processor_busy 80 percent"
Created new threshold (6).
I believe the problem is that in "dfm perf threshold" the counter should be in format object-type:counter-name. Domain utilization needs also a label with domain name to be meaningful.
Is there any way to workaround this ??
1 REPLY 1
Highlighted
Re: Is it possible to create threshold for domain utilization?
There is no workaround. PA doesnt support creating thresholds on label counters.
Regards
adai
Check out the KB!
Knowledge Base
All Community Forums
