Is there relationship between WFA and DOT PowerShell toolkit?
korns
Hi,
Novice question: I understand that WFA uses PowerShell under the covers. I'm also aware that NetApp offers the Data ONTAP PowerShell Toolkit (ref: https://communities.netapp.com/community/products_and_solutions/microsoft/powershell )
Is there any relationship between these kits/tools? Does WFA utilize the PS toolkit comlets? ... or does it have it's own PS code and cmdlets?
The reason I ask is I'm wondering if it might make sense to use them together or is it even possible to install them both on a WFA server.
4 REPLIES 4
tanmoy
PowerShell tool kit comes bundled with WFA installer; so once you install WFA you get the tool kit also.
We do utilize PS toolkit comandlets to develop commands in WFA.
So you don't need to install DOT PowerShell tool kit separately on a WFA server.
Thanks
Tanmoy
briankrussell
I see the Data ONTAP toolkit installed on my WFA system here:
c:\Program Files\netapp\WFA\PoSH\Modules\DataONTAP
How do I update my powershell $PROFILE to Import-Module DataONTAP?  The DataONTAP module is not listed if I do Get-Module -listavailable
Thanks!
Brian
kandati
Hi Brian,
The following way you can import the modules,
PS C:\Documents and Settings\Administrator> Get-Item 'C:\Program Files\NetApp\WFA\PoSH\Modules\*' | Import-Module
Here the "*" makes importing the other two WFA modules along with DataONTAP..!
The same thing can be added to your $PROFILE file..!
PS C:\Documents and Settings\Administrator\Desktop> Get-Module
ModuleType Name                      ExportedCommands
Manifest   DataONTAP                 {Invoke-NaSnapmirrorThrottle, Resume-Nc...
Binary     WFA                       {Copy-NaVM, Get-NaCredentials, Set-WfaC...
Script     WFAWrapper                {Set-WfaAcl, New-WfaZapiServer, Connect...
Warm Regards
Sivaprasad K
briankrussell
Thanks!  Works nice.
