Data Infrastructure Management Software Discussions
OCI 7.3.1 shows Storage Pools with Raw Capacity smaller than capacity
OCI shows Storage Pools with Raw Capacity smaller than than capacity.  Why is this the case?   Screen shot attached.
2 REPLIES 2
Re: OCI shows Storage Pools with Raw Capacity smaller than than capacity
I wouldn't have expected that.
Are you running current patches for your ONTAP data sources?
Those aggregates don't happen to contain a mix of backend and internal storage, do they?  (I'm not even sure there is a situation where that configuration would be allowed in ONTAP; been out of that specialty for a while.)
Highlighted
Yes, we are running the latest patches. And no disks (SSD's) are mixed with the SAS drives.   I was wondering  -- could this be a case inwhich the "Capacity (GB)" column is reporting Storage Efficiency (dedupe, compression, compaction..)?
Try the new BETA Support Site!
Beta Support Site
Forums
