OCI Performance and Capacity data marts are not being built due to some unhappiness
mmodi
Hello,
I have noticed that the performance data marts "dwh_performance" are not being built even though the ETL schedules run successfully (at least the status is - "completed").
I have tried a reset of the DWH database, including inventory but no luck retrieving performance data.
Is there a known solution post "Reset" of database that can fix this issue?
Thanks
Modi
1 ACCEPTED SOLUTION
mmodi
Tried the following as I was happy with loosing data > 14 days i.e. day not present in OCI instance -
  • Reset DWH DBs
  • Build from History
3 REPLIES 3
moechnig
How do you know the performance mart is not being built?  You have Perform and Plan both licensed, right?
mmodi
OCI is licensed -
mmodi
  • Reset DWH DBs
