OCUM Core not collecting info from VSMs
brunopad87
Hello,
I've updated OCUM Core/DFM to 5.2R1 yesterday and it's not showing volume and LUN data from VSMs.
It shows data from cluster, nodes and even root vols. Is it the same bug from described on http://mysupport.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=814072 ?
Thanks,
9 REPLIES 9
arunchak
HI,
Please maintain the MTU at 1500. The BURT clearly indicates that there are issues in discovery with non default MTU size.
If the MTU is different than 1500 then set it back to 1500 and see if the issue goes off.
If not, Could you check in /opt/NTAPdfm/dfmmonitor.log for any discovery errors or issues.  Could you paste here if any.
Thanks,
  Arun
brunopad87
The log states:
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-01:5a present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-01:5b present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-01:6a present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-01:6b present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-02:5a present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-02:5b present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-02:6a present in API but not SNMP
Jun 25 10:21:58 [DFMMonitor: WARN]: [2752:0xa80]: HDI.hdi.br: Adapter HDI-02:6b present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-01:5a present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-01:5b present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-01:6a present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-01:6b present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-02:5a present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-02:5b present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-02:6a present in API but not SNMP
Jun 25 10:27:59 [DFMMonitor: WARN]: [2752:0x1324]: HDI.hdi.br: Adapter HDI-02:6b present in API but not SNMP
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: vs_progress:vs_progress_fc6a_lif3. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: vs_progress:vs_progress_fc5a_lif1. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: HDIST03:HDI-02_fc_lif_3. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: HDIST03:HDI-02_fc_lif_4. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: vs_sql:vs_sql_fc5a_if1. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: vs_sql:vs_sql_fc6b_if2. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: vs_vmware:HDI-02_fc5b_lif_2. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: HDISTD:vs_hdistd_fc5b_if1. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: HDISTD:vs_hdistd_fc5b_if2. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: vs_progress:vs_progress_fc5b_lif4. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: vs_progress:vs_progress_fc6b_lif2. Lif may be down.
Jun 25 10:32:32 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: vs_sql:vs_sql_fc6a_if3. Lif may be down.
Jun 25 10:32:33 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: vs_vmware:HDI-02_fc6a_lif_3. Lif may be down.
Jun 25 10:32:33 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: HDIST03:HDI-01_fc_lif_3. Lif may be down.
Jun 25 10:32:33 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: HDIST03:HDI-01_fc_lif_4. Lif may be down.
Jun 25 10:32:33 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-02) details for the the Lif: vs_sql:vs_sql_fc5b_if4. Lif may be down.
Jun 25 10:32:33 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: vs_vmware:HDI-01_fc5a_lif_1. Lif may be down.
Jun 25 10:32:33 [DFMMonitor:ERROR]: [2752:0x116c]: ifmon_report_one_lif: Failed to find Home node (HDI-01) details for the the Lif: vs_vmware:HDI-01_fc6b_lif_4. Lif may be down.
So, I believe it's the MTU size since DFM isn't finding LIF status. I'll change it and let you guys know.
Thanks!
Bruno
arunchak
Hi,
Please set the MTU to 1500 and then do the discovery. Please let us know if you are seeing issues even after that.
Thanks,
Arun
brunopad87
Hi there,
I double checked all interfaces with role configured as data and if_groups and all is set to 1500. Only cluster interfaces are set to 9000.
net port show
  (network port show)
                                      Auto-Negot  Duplex     Speed (Mbps)
Node   Port   Role         Link   MTU Admin/Oper  Admin/Oper Admin/Oper
HDI-01
       a11b   data         up    1500  true/-     auto/full   auto/10000
       a12b   data         up    1500  true/-     auto/full   auto/10000
       e0M    node-mgmt    up    1500  true/true  full/full   auto/100
       e0a    data         up    1500  true/true  full/full   auto/1000
       e0b    data         down  1500  true/true  full/half   auto/10
       e1a    cluster      up    9000  true/true  full/full   auto/10000
       e1b    data         up    1500  true/true  full/full   auto/10000
       e2a    cluster      up    9000  true/true  full/full   auto/10000
       e2b    data         up    1500  true/true  full/full   auto/10000
HDI-02
       a21b   data         up    1500  true/-     auto/full   auto/10000
       a22b   data         up    1500  true/-     auto/full   auto/10000
kryan
Please post "net int show" as well.
Thanks,
Kevin
brunopad87
Here it is:
net int show
  (network interface show)
            Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
HDI
            cluster_mgmt up/up    10.7.3.66/22       HDI-02        e0a     false
HDI-01
            clus1        up/up    169.254.130.125/16 HDI-01        e1a     true
            clus2        up/up    169.254.104.141/16 HDI-01        e2a     true
            mgmt1        up/up    10.7.3.67/22       HDI-01        e0M     true
            smv_lif1     up/up    10.7.3.73/22       HDI-01        a11b    true
HDI-02
            clus1        up/up    169.254.117.169/16 HDI-02        e1a     true
            clus2        up/up    169.254.44.6/16    HDI-02        e2a     true
            mgmt1        up/up    10.7.3.68/22       HDI-02        e0M     true
            smv_lif2     up/up    10.7.3.75/22       HDI-02        a21b    true
HDIST02_NW
            HDIST02_NW_lif1
                         up/up    10.7.3.74/22       HDI-02        e0a     false
            HDIST02_NW_lif2
                         up/up    10.7.3.230/22      HDI-01        e0a     false
HDIST03
            HDI-01_fc_lif_3
                         up/down  20:0b:00:a0:98:40:39:56
                                                     HDI-01        6a      true
            HDI-01_fc_lif_4
                         up/down  20:0a:00:a0:98:40:39:56
                                                     HDI-01        5b      true
            HDI-02_fc_lif_3
                         up/down  20:0f:00:a0:98:40:39:56
                                                     HDI-02        6a      true
            HDI-02_fc_lif_4
                         up/down  20:0e:00:a0:98:40:39:56
                                                     HDI-02        5b      true
            HDIST03_data_lif1
                         up/up    10.7.3.69/22       HDI-02        a21b    false
HDIST04
            HDIST04_cifs_lif1
                         up/up    10.7.3.70/22       HDI-02        e0a     false
HDISTD
            HDISTD_cifs_nfs_lif1
                         up/up    10.7.0.40/22       HDI-01        a11b    true
HDISTD
            vs_hdistd_fc5b_if1
                         up/up    20:07:00:a0:98:40:39:56
                                                     HDI-01        5b      true
            vs_hdistd_fc5b_if2
                         up/up    20:09:00:a0:98:40:39:56
                                                     HDI-02        5b      true
vs_progress
                         up/up    20:00:00:a0:98:40:39:56
                                                     HDI-01        5a      true
                         up/up    20:03:00:a0:98:40:39:56
                                                     HDI-02        5b      true
                         up/up    20:02:00:a0:98:40:39:56
                                                     HDI-02        6a      true
                         up/up    20:01:00:a0:98:40:39:56
                                                     HDI-01        6b      true
            vs_progress_lif1
                         up/up    10.7.3.71/22       HDI-02        a21b    false
vs_sql
            vs_sql_fc5a_if1
                         up/up    20:1e:00:a0:98:40:39:56
                                                     HDI-01        5a      true
            vs_sql_fc5b_if4
                         up/up    20:21:00:a0:98:40:39:56
                                                     HDI-02        5b      true
            vs_sql_fc6a_if3
                         up/up    20:20:00:a0:98:40:39:56
                                                     HDI-02        6a      true
            vs_sql_fc6b_if2
                         up/up    20:1f:00:a0:98:40:39:56
                                                     HDI-01        6b      true
            vs_sql_mgmt  up/up    10.7.3.76/22       HDI-02        a22b    true
            vs_sql_ndmp01
                         up/up    10.7.0.80/22       HDI-01        e0a     false
vs_vmware
            HDI-01_fc5a_lif_1
                         up/up    20:04:00:a0:98:40:39:56
                                                     HDI-01        5a      true
            HDI-01_fc6b_lif_4
                         up/up    20:0c:00:a0:98:40:39:56
                                                     HDI-01        6b      true
vs_vmware
            HDI-02_fc5b_lif_2
                         up/up    20:10:00:a0:98:40:39:56
                                                     HDI-02        5b      true
            HDI-02_fc6a_lif_3
                         up/up    20:06:00:a0:98:40:39:56
                                                     HDI-02        6a      true
            vs_vmware_mgmt
                         up/up    10.7.3.72/22       HDI-02        a21b    true
36 entries were displayed.
kryan
Very good - the cluster_mgmt is 1500 MTU, so if the network and UM server are also set to 1500 then 814072 is not cause of your problem.
You should consider opening a support case.
Thanks,
Kevin
brunopad87
OK, I'm gonna open a case right now.
Thank you guys!
kryan
This bug will be to blame for UM 5.x Cluster-Mode monitoring issues when any of the network interfaces between (and including) the UM server to the cluster management LIF have an MTU other than 1500.
Thanks,
Kevin
