Data Infrastructure Management Software Discussions
Highlighted
Re: OnCommand Core 5.0 - perfdata directory setting problem!
Hi guys,
Would this burt perhaps be related to my problem as well?  My OnCommand 5 DB backups (snapshot backups)
began failing.  In trouble shooting it with an archive backup type , DFM seems to believe my perfdata is located on my D drive where I didn't even have a folder for at the path listed.  I can clearly see that it is writing the data on my E still, which is where it should be so that my snapshots work.  I restarted the whole server a week ago.  How is a service restart going to differ in fixing the problem as opposed to a reboot?
Thanks
Highlighted
I finally was able to restart my dfm services per the list BURT and now my perfdata path points back to the correct location and I can once again take snapshot backups of my OnCommand DB.  Any ideas when this BURT will be fixed?
Thanks
Michael
Highlighted
Hi Michael,
     This is being targeted for the GA release of 5.0.1. BTW can you add your case to this burt or share your case # for the same?
Regards
adai
Highlighted
Thanks for the information. That is good to know. I have not opened a case yet, but I’ll go open one up and have it attached to the BURT.
Thanks
Highlighted
Hi Adai
Any ETA for 5.0.1?
And will you level the version numbers also for Management Console?
Just makes it unneccessary complicated with OnCommand5, Mgmt-Console3.1 and ProtMgr4 and so on...
thanks, peter
Check out the KB!
NetApp Insights To Action
All Community Forums
