OnCommand Insight reporting SnapMirror replication bandwidth consumed per SVM for chargeback?
calving
Can anybody suggest a way to get OnCommand Insight to report replication bandwidth used per SVM for SnapMirror replications?
For example, in a secure multi-tenant environment each tenant will be assigned one or more SVMs.  We need to be able to report how much data has been replicated from each SVM over a given period of time.
I am able calculate this data from the following command and equivilent API calls using NMSDK:
cluster1::> snapmirror show-history -fields transfer-size,start-time,end-time
destination-path operation-id                         start-time         end-time           transfer-size
svm123:volume123 845e8488-a657-4272-9bbf-b8ad2cacc142 5/30/2017 11:00:00 5/30/2017 11:00:01 236KB
svm123:volume123 3752c78e-0402-47eb-affd-2def92f123a5 5/30/2017 10:55:00 5/30/2017 10:55:01 228KB
svm123:volume123 062272d7-da67-45b7-8e9b-49f3ae310363 5/30/2017 10:50:00 5/30/2017 10:50:01 228KB
svm123:volume123 66ef17eb-7074-4a8e-9c5f-06c7a58c3843 5/30/2017 10:45:00 5/30/2017 10:45:01 220KB
svm123:volume123 e3516863-55c2-46c2-9f76-1cbd14398838 5/30/2017 10:40:00 5/30/2017 10:40:01 228KB
I just cannot figure out how to report this from within OCI. Thanks in advance for any advice you can provide.
--calvin
1 ACCEPTED SOLUTION
ostiguy
OCI does not purport to support this use case. With the help of Professional Services, it may be possible to build/script something that collects and stores this data, but OCI doesn't natively claim to do replication throughput monitoring/accounting
2 REPLIES 2
ostiguy
calving
Thanks. That's what I was afraid of.  --calvin
