Overdeduplication level of the volume
ajay_nabh
Hi Guys
I saw this error message at Operation manager console
Over deduplication percentage ( 173.68% ) of the volume exceeds the over deduplicated threshold ( 150.00% ). Increase the threshold or resize the volume
can you guys please explain me how can I attend to it as I did not know that you can over deduplicate? where is the setting to Change this threshold??
thanks to all dedupe experts
Ajay
1 ACCEPTED SOLUTION
adaikkap
The event tries to convey that, if you un-dedupe this volume, the volume cannot contain the data, as its smaller than the volume total size due to dedup which is
The sum of volume used space and saved space (as a result of deduplication) expressed.
So to avoid this, increase the volume size.
Regards
Adai
5 REPLIES 5
adaikkap
Regards
Adai
MUTHUSONA
I have a query. What is Over deduplication. Is it not saved space less than 100%???
Let us say a volume of 100GB, contains 100GB data, upon dedup running it saved 30GB. Hence now, data = 70GB, available (saved) = 30GB. Obvious saved space 30%.
If I un dedup, saved 30GB gonno come back. Still equates to 100%. where comes over dedup
Thanks in advance
Muthu
amirm
Hi Muthu,
As Adai has explained above, dedup is an event that alerts that you are trying to store the data that may not fit in the volume if you un-dedup per the thresold set volOverDeduplicatedThreshold.
However for the example that you sighted, dedup perecentage is 30% which doesn't look like to be case of over-deduplication. Overdeduplications is when the sum of space savings due to deduplication + data reaches/almost equal to the threshold set i.e. volOverDeduplicatedThreshold percent of the total volume size.
Thanks,
-Amir
lovik_netapp
or change the threshold in operations manager
