Putting a volume or qtree into DFM groups from WFA?
waynesilvia
Has anyone attempted to add a volume and or qtree to a DFM group via WFA?  I have an existing workflow that creates a volume and tree and would like to be able to put them into existing groups in oncommand/DFM 5.2 (cluster Mode).  If you have done it for 5.2 (7-mode) that would also be useful for different workflows.
1 ACCEPTED SOLUTION
abhit
Hi:
Can you please try this command. This is a certified command shipped with WFA:
"Add member to resource group"
This adds a member to a group on the target DataFabric Manager server.
If either a member or group name is specified and not the id, the name must be fully qualified.
Regards
Abhi
4 REPLIES 4
abhit
Hi:
Regards
Abhi
waynesilvia
Thank you pointing this out...I did a quick test workflow and it did appear to move it to the group.  WFA has it under Storage not CM_Storage..so I missed it.  Very happy it worked.
adaikkap
Does it help if it's moved to a different schema like manageability instead of the storage and cm_storage?
waynesilvia
Yes if there were commands that truly spanned storage and cm_storage or did not really apply to either of those.  If there was a manageability schema with additional commands and sample workflows that would help.  I would love to see more DFM oncommand command examples as certified commands.
