Resync snapmirror connection in DFM
zbrenner_1
Hi,
I've got a question about DFM relationships. When I did create a connection with protection manager.
It was only a snapmirror and did it well. In cli unfortunately  I quiesced and breaked this connection for a lunclone on DR site.
When I tried to resync, it failed with error messages (missing snap mirror.conf entry).
How could I resync this connection without reinitialize the whole volume?
Thanks
Zoltan
1 ACCEPTED SOLUTION
zbrenner_1
Ok I find it.
dfdrm mirror resync ID did the same as in cli snapmirror resync
4 REPLIES 4
zbrenner_1
Ok I find it.
adaikkap
Hi
The dfdrm cli are basically wrapper over snapmirror cli. So all you could do with cli can be done with dfdrm.
Regards
Adai
zbrenner_1
Yes, thanks Adai,
After i've got one further problem. My Protection Policy was local backup, DR mirror to secondary and Snapvault from DR mirror volume.
And when I resync the broken snapmirror connection with dfdrm, its delete the snapvault base snapshot from snapmirrored volume, so I had to reinitialize the snapvault relationship:(
Regards
Zoltan
adaikkap
Hi Zoltan,
     Looks like the base snapshot of the SV was a locked snapshot that got deleted due to resync.
Regards
adai
