Slow workflow execution
francoisbnc
I wonder why workflow execution is so slow at the first line of a command 2 minutes in this exemple with WFA 2.2 (same behavior with 2.1 version) without LDAP auth.
11:45:36.381 INFO  [Create volume] ### Command 'Create volume' ###
11:47:12.276 INFO  [Create volume] Executing command: ./Create_volume8173598297431862987.ps1 -AggregateName 'sas_t2_002' -Array '10.139.32.11' -Size '1000' -VolumeGuarantee 'none' -VolumeName 'test'
11:47:12.744 INFO  [Create volume] Get-WfaCredentials -Host 10.139.32.11
11:47:12.900 INFO  [Create volume] Credentials successfully provided for '10.139.32.11'
11:47:13.103 INFO  [Create volume] Connect-NaController (with credentials) -Name 10.139.32.11 -Timeout 60000 -ErrorAction Stop
11:47:24.662 INFO  [Create volume] Connected to controller
11:47:24.927 INFO  [Create volume] Creating a new volume - name 'test' , aggregate name 'sas_t2_002' , size '1000m' , volume guarantee 'none'
11:47:34.147 INFO  [Create volume] Command completed, took 117735 milliseconds
My productive wotkflows take more than 30 minutes just for cloning 5 volumes and mapping luns inside to igroup.
Any suggestions appreciate.
François
1 ACCEPTED SOLUTION
jcbettinelli
Salut François,
We had such kind of issue with SnapManager Service for one of our customer.
There is an option in Internet Explorer called "Check for publisher's certificate revocation". I'm wondering if this option could help as well in your problem.
If this is enable, some programs needs an internet access.
That would be nice if you could give it a try
Cheers,
JC
49 REPLIES 49
sinhaa
Francois,
         Run the .NET repair tool and see if it helps.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
stevenj
Francois,
What exactly did you change within your server to get the workflow to speed up? Are you talking Internet settings (as in the proxy setups in IE, etc)?
francoisbnc
Hello stevenj,
In my case WFA service was running with an active directory account, because I use some workflows commandlet that needs credentials, as get-service for exemple.
So I had to login interactively  with this service account and set proxy setting or set via regedit the correct HKEY_USERS Keys
[S-1-5-21..........\Software\Microsoft\Windows\CurrentVersion\Internet Settings]
"MigrateProxy"=dword:00000001
"ProxyEnable"=dword:00000001
"ProxyHttp1.1"=dword:00000000
"ProxyServer"="http://ProxyServername:80"
François
jcbettinelli
Salut François,
Cheers,
JC
francoisbnc
Hi jc,
You are totaly right.
Removing Check for publisher's certificate revocation fix the problem as well.
François
stevenj
Was this done on the workstation that the workflows were executed from or on the server? What user account? Still seeing issues with the workflows taking about 45 seconds to load the powershell modules.
stevenj
Ignore - Read the response.... Changed the setting under the user that runs the WFA Server Service and dropped the load from 45 seconds to under 2 seconds.
Thanks!!
elic_co
Hi all.
Tried to do all the examples shown and still takes long time like other posts.
Tried to change the "revocation" setting in Internet Explorer, tried creating the powershell.exe.config file with relevant configuration, also tried removing executor="http-executor" from xml file and restarting service,  and server is already 2008R2.
Any other ideas?
WFA Server service runs with local system.
Thanks.
