Data Infrastructure Management Software Discussions
Highlighted
Using WFA to upgrade ONTAP
I have seen the posts about using WFA to upgrade older 7-mode systems, but has anyone had any luck with creating a flow to upgrade CDOT systems? Mainly interested in automating 9.X versions using WFA.
2 REPLIES 2
Re: Using WFA to upgrade ONTAP
Hi
I think in 7 mode it made sense to do as there were a few failovers to do manually..
in Cdot it's all automated in the controller. so not much point to it.
you can perhaps create a function in WFA that load the image another that execute the install if you really like.
Gidi
That’s really what I’d like to do is find a way to stage the ONTAP image on all the clusters I have in OnCommand and then be able to select which clusters to upgrade without having to touch each cluster individually. It sounds like I’d need a permeant web server up and running that has a valid URL to an image and use WFA to run cmdlts against the clusters to pull that image. I was just hoping someone would have a flow already.
Forums
