Data Infrastructure Management Software Discussions
Highlighted
Volume offline workflow
May I know if there if anyone already tried to create a workflow that just offline a volume?
thanks.
5 REPLIES 5
Highlighted
Re: Volume offline workflow
The below command code will do for you.
##Begin Code
param (
[parameter(Mandatory=$true, HelpMessage="Cluster IP address")]
[string]$Cluster,
[parameter(Mandatory=$true, HelpMessage="Volume name")]
[string]$VolumeName,
[parameter(Mandatory=$true, HelpMessage="Storage Virtual Machine name")]
[string]$VserverName
Connect-WfaCluster $Cluster -Vserver $VserverName
Set-NcVol -Name $VolumeName -Offline
##End code
sinhaa
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Highlighted
Sinhaa,
For Clustered Data OnTap, we may need to un-mount the volume before we take it off-line.
Filer-sith,
I have a remove volume workflow that, un-mounts the volume, takes it offline, and sends an email to notify WFA Admins that a volume deletion is requested.  The workflow has an approval point after the email, and once approved it can remove the volume.  My lab is down at the moment, but if this workflow would help you, I can clean I up and post it.
Mike
Highlighted
Right Mike. Added the line to Un-mount the volume.
##Begin Code
param (
[string]$Cluster,
Dismount-NcVol -Name $VolumeName
##End code
Highlighted
How about for 7-Mode only? And if it possible, can put it in .dar file compatible with WFA 2.2. Thank you so much
Highlighted
Im creating a new command since this isnt a standard one.
Whats the string representation field?
Cloud Volumes ONTAP
Review Banner
All Community Forums
