correct syntax for query using LIKE with predefined variable?
stephen2
trying to use like in a query referencing a predefined variable and cant get the syntax right.
SELECT v.name AS VolumeName
  FROM cm_storage.volume v, cm_storage.cluster c, cm_storage.vserver vs
WHERE     (c.id = vs.cluster_id)
       AND (vs.id = v.vserver_id)
       and v.name like '${LastVol}'
       order by v.name desc
limit 1
Anyone know if this can be done, and if so, what the syntax is?
3 REPLIES 3
ag
NetApp
Hi Stephen,
That is the correct syntax. It is working for me.
What kind of error is being thrown, if any?
abhit
Hi Stephen:
Where are you using/testing this query? In WFA or using it outside WFA?
If you are using in WFA which version of WFA are you using?
As 'ag' replied, it is syntactically correct, WFA is not complaining.
If using WFA, are you trying to use it in a user input query or you are using in a filter?
Regards
Abhi
stephen2
Hey guys, it must have been something stupid. I tried in another workflow and the syntax worked correctly
