Data Infrastructure Management Software Discussions
Highlighted
network discovery problem
Hi,
I have a lot of subnets being discovered that are spread accross multiple oncommand servers. It seems on any server that has more than two subnets, there will be exactly one subnet that is not being discovered. I can go in and do 'dfm discover id' and it will say network is being rediscovered, but when i list the networks it does not have a discovery time, and the filers on that network arent being discovered.  I am running the lastest version (5.2) on windows 2008.  Any thoughts?
2 REPLIES 2
Highlighted
Re: network discovery problem
Hi
   Can you show an example ? Also pls paste the output of dfm network list. Do check what is the value for the following options
dfm options list | findstr /i discover
Regards
adai
Highlighted
As you can see from the below output one network hasnt been discovered. I ran dfm discover on it, but in the discovery log it dosnt show up.
D:\Program Files\NetApp\DataFabric Manager\DFM\bin>dfm network list
ID   Network                                    Prefix Length  Hop Count  Last S
earched          Deleted
130 10.38.0.0                                  16 bits             0     06 Nov
02:18           No
131 10.42.0.0                                  16 bits             0
                 No
132 10.48.0.0                                  16 bits             0     05 Nov
01:00           No
133 10.49.0.0                                  16 bits             0     05 Nov
09:52           No
134 10.50.0.0                                  16 bits             0     05 Nov
18:54           No
D:\Program Files\NetApp\DataFabric Manager\DFM\bin>dfm options list | findstr /i
discover
discoverAgents                        Enabled
discoverClusters                      Enabled
discoverEnabled                       Enabled
discoverHostInitEnabled               Enabled
discoverHosts                         Enabled
discoverInterval                      15 minutes
discoverNetworks                      Enabled
discoverTimeout                       5 seconds
discoverVfilers                       Enabled
hostEnclosureDiscoveryEvents          Disabled
networkDiscoveryLimit                 15
serverAPILogExclude                   host-service-discover|dfm-about
snapshotDiscoveryEventsEnabled        No
Cloud Volumes ONTAP
Review Banner
All Community Forums
