problem with a filter
solal
hey guys.
when trying to re-write a filter i have to do something similar but a bit else,
i encounter the following error while trying to save the filter's query:
Filter 'Filter luns for DS by name prefix in a specific volume' returned attributes does not contain all natural keys. Filter's returned attributes '[id, name, num_part]' , dictionary entry natural keys '[array.ip, name]'
i tried the containing query in a query builder in Toad and it returned data fine.
ideas?
SELECT
    storage.lun.name,
    storage.volume.id,
    SUBSTRING_INDEX(storage.lun.name,
    '${lun_name_prefix}',
    -1) AS num_part
FROM
    storage.volume,
    storage.lun
WHERE
   storage.lun.volume_id = storage.volume.id
    AND storage.lun.name LIKE '${lun_name_prefix}%'
ORDER by
    num_part desc
thanks!
solal.
1 ACCEPTED SOLUTION
ag
NetApp
Hi Solal,
Try this:
SELECT
    storage.lun.name as 'name',
    storage.array.ip as 'array.ip',
    storage.volume.id,
    -1) AS num_part
FROM
    storage.volume,
    storage.lun,
    storage.array
WHERE
    AND storage.array.id = storage.volume.array_id
ORDER by
    num_part desc
3 REPLIES 3
ag
NetApp
Hi Solal,
Try this:
SELECT
    storage.volume.id,
    -1) AS num_part
FROM
    storage.volume,
    storage.lun,
    storage.array
WHERE
ORDER by
    num_part desc
solal
Hey Anil.
Thanks for that!
What was it? I understand the array.ip row was missing, right? I didn't write it coherently...
Why does it affect this query?
Thanks,
Soli.
ag
NetApp
Hi Solal,
The filter should return all the natural keys for the object being filtered. It can return other attributes as well but it SHOULD return the natural keys at least.
For dictionary object volume, the natural keys are:
1. array(reference)
2. name
For a reference, you will have to return all the natural keys of that Object. In this case it is the array that is being referenced.
The only natural key in array is the IP, i.e. "array.ip".
Hope this helps
-Anil
