"perf:system:load_total_mbps:breached" Can some one please help me to address this alert.
Naveenkumarp22
Hi All,
Last night i got an alert from operations manager. Please find the alert below.
Event Description: A 'perf:system:load_total_mbps:breached' event has been detected
Can anyone please help me to address this.
1 ACCEPTED SOLUTION
Renifa
Hi,
This is not exactly a problem.Its just an alert stating that the threshold was cross. The threshold can be changed if this happens frequently.
If you need to change the threshold settings follow the netapp Kb "https://kb.netapp.com/support/index?page=content&id=3010964"
Also check the OnCommand Unified Manager Performance Advisor Administration Guide "https://library.netapp.com/ecm/ecm_download_file/ECMP1217275" page no 85, to know how the load_total_mbps parameter is calculated.
Hope this helps.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
Renifa
Hi,
Hope this helps.
Naveenkumarp22
Thank you so much 🙂
Spoiler
Spoiler
Spoiler
