Hi,
As I mentioned, once you select the ArrayIP then it will list only the primary volumes in it, the volumes which has mirror relationships. you can see the UserInput query which is listing it.
Are you facing the "unexpected error" consistently..?
1)in the resize volume can we just put the size increase we need instead of the target size
Ans: Yes, you can just provide the value like, +20 or -20
2)also can we check the aggregate free space before increasing the volume.
Ans: Yes, for that you have to enhance UserInput query, go to Workflow edit view-> Settings->UserInputs->double click on PrimaryVolume-> Click on "View or edit the SQL query" link, and replace with the below query.
select
storage.volume.name,
storage.volume.size_mb,
storage.aggregate.available_size_mb
from
storage.volume,
storage.array,
storage.vsm,
storage.aggregate
where
storage.array.id = storage.volume.array_id
AND storage.array.ip = '${PrimaryArrayIP}'
and storage.volume.id= storage.vsm.volume_id
and storage.aggregate.id = storage.volume.aggregate_id
GROUP by
storage.volume.name
This workflow currently not listing secondary volumes while filling the fields. But, we can do that also to list all the secondary volumes and their aggregates available capacity etc, for the selected PrimaryVolume..!
Warm Regards
Sivaprasad K
