Data Infrastructure Management Software Discussions
Highlighted
volume-autosized events in OM 3.8
All,
I see some old BURT activity around this but wanted to ask the communities before openning a case and BURT.
I have DFM 3.8 and am rolling out vol autosize in a limited environment.  I see that DFM 3.8 has an event to record this with a default of "information" severity.
I have enabled the autosize rule on some volumes and watched it work.  I do not see that DFM events of any severity have been recorded.
Does anyone else have experience with these events being created properly?
2 REPLIES 2
Re: volume-autosized events in OM 3.8
You have to set the snmp trap host as your DFM server in filer to get that event.
Filer> snmp traphost add
You will get event once vol autosize triggers.
Thanks
Tanmoy
You'll also need to ensure the trap listener is enabled in DFM.
dfm options list SnmpTrapListenerEnabled
Option Value
Forums
