Data ONTAP Discussions
Highlighted
7MTT Snapmirror replication and network compression
Can't figure out how to get compression enabled on a snapmirror relationship established with 7MTT. Relationship is created fine using the tool. Non-compressed transfer works just fine. I've got many TB worth of data to move and I'd rather see it take a couple days vs weeks.
Policy has compression set to true on the CDOT cluster. Temp license for Snapmirror is installed on both source and target. I've restarted baseline copies and started them from scratch after the policy change. Verified the appropriate policy is applied to the relationship.
Source: 8.2.3P6
Target: 9.4P3
Any guidance much appreciated. I'm pretty new to CDOT.
Mike
2 REPLIES 2
Highlighted
Re: 7MTT Snapmirror replication and network compression
https://library.netapp.com/ecm/ecm_download_file/ECMLP2494078
p.6
Features and volumes not supported for transition
- Network compression for SnapMirror
Highlighted
thanks. obviously missed that. 😛
Try the NEW Knowledgebase!
NetApp KB Site
Forums
