ONTAP Discussions
7MTT does not connect to configured LIF
thokelly
Hello,
I configured a migration project and added a new LIF in Networking, since you cannot chose an existing LIF.
But the snapmirror connection connects to a intercluster LIF (1 GBit) instead of the configured LIF (10Gbit) in an SVM where the volume goes.
I do not find any errors/failures in the logs.
Happens on both Clusters (its a MetroCluster).
When I testes my first projects, it used to work.
Any hints?
/Tom
1 ACCEPTED SOLUTION
SeanHatfield
You can choose which source IP(s) to use on the 7mode source systems, but it always uses the intercluster lifs on the destination cluster.   The lifs you create in a 7MTT project are data lifs on the destination SVM(s).  If 1gb is not enough for your snapmirror transfers then place those lifs on higher speed ports.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
peiffer83
I just completed a 7mtt migration.  I had a interface group which had my two 10gb connections in it (A0A).  I created another lif on these ports for intercluster.  For example:
A0A=e0g,e0f
Intercluster lif is configured on A0A.
Here is a guide:
https://library.netapp.com/ecmdocs/ECMP1547469/html/GUID-3E74D0DB-CA7D-437A-920C-CED37D55622F.html
Also if you have support they can help you with the 7MTT
SeanHatfield
