ONTAP Discussions
AutoSupport issue on FAS3160
jhenschell
I had a disk fail on ctlr2 of my FAS3160 over the weekend, then I discovered autosupport on this same controller is not working.  I'm running 8.0.1 7-Mode and I know autosupport worked at one time.  The odd thing is ctlr1 is working just fine and from what I can see the options autosupport is set up identical.  Has anyone else had a similar issue with autosupport?
1 ACCEPTED SOLUTION
daehnrich_bsh
There was a bug with ASUP, use 8.0.1P4 like pascal said and asup should work fine.
5 REPLIES 5
pascalduk
I had a similar issue with (weekly) autosupports and Ontap 8.0.1 7-mode on 1 filer and not on 3 others running the same ontap version. When set to minimal content it worked, but for complete content the autosupport was looping and eventually stopped. This was a known bug. After upgrading to 8.0.1P4 the weekly autosupport worked again.
daehnrich_bsh
shahabasm
@pascal/daehnrich,  can you please provid the bug number if you have it. We are having the same issue with autosupport., Thanks
pascalduk
In my case it was bug 370156.
jhenschell
This was helpful, thank you for your reply.
