Data Backup and Recovery
Difference in pri en sec snapshots ONTAP 9.3
Sander
Hi community,
thing is i'm struggeling with snapshot sizes on primary and secondary ONTAP 9.3P2 controllers.
Am i right to presume that when i take a daily snapshot on the primary with a snapmirror label _daily on it (let's say 100GB), this is transferred to the secondary Netapp with a SnapMirror XDP policy, this has to be the same size on the secondary (100GB)? I mean SM policy picks the SnapShot with the _Daily SM label, so it has to be the same snapshot on the secondary?
I see some big differences in snapshot size with the same name on pri and sec. Netapp.
Attached is a file with volumename, snapshotname and sizes.
1 ACCEPTED SOLUTION
mrahul
The update from primary to secondary is only the data that has changed since the previous update.
2 REPLIES 2
mrahul
DataOntaper
Consideration for the Size of Snapshots/Data on 2 differnt Controllers:
Detailed information's about impact of Dedupe and Compression can be found in our Technical Report
TR-4476 NetApp Data Compression, Deduplication,and Data Compaction
